Engineering
Fundamentals
Engineering
Calculators
Applications and Design
Engineering Analysis
** Search this PAGE ONLY, click on Magnifying
Glass **
Material Testing and Engineering
- Conversion of Hardness-to-Hardness Values for Cold Working Steels per. ISO 18265
- Tensile to Hardness Conversion per ISO 18265 Table Calculator
- Brinell Hardness Testing Brinell Hardness
Testing in this test a standard constant load,
usually 500 to 3,000 kg, is applied
Brinell Hardness Testing Equation The Brinell
hardness test uses a hardened steel ball indenter
- Brittle Fracture Analysis Calculator and Equation
Case Hardening of Steel 220 Pages Premium
Memebrship Required
Methods of Measuring Case Depth Hardness
Comparative Hardness Scales for Steel Table
Coefficients Linear Thermal Expansion Thermal
expansion is the tendency of matter to change
in volume in response to a change in temperature.
Critical Temperature and Melting Point for Common
Engineering Materials
Density of Various Solids Tables These tables
gives the range of density for miscellaneous
solid materials whose characteristics depend
on the source or method of preparation.
Engineering and Applications Factor of Safety
Review Factor of Safety (FOS) for structural
applications
Engineering Physical Metallurgy
- Engineering Properties of Typical Rock Types
Fatigue strength diagrams of quenched and tempered
steels, DIN 17200 - EN 10083
Fatigue strength diagrams of general purpose
structural steels, DIN 17100, test piece
diameter d = 10 mm.
- Galvanic
Compatibility ( Corrosion Control) Galvanic
corrosion is the process by which the materials
in contact with each other oxidizes or corrodes.
Gear Material Steels for Industrial Gearing
Gearing materials are typical steel used within
industrial applications.
Gold Precious Metal UNS Number Specification
Table Gold Unified Numbering System (UNS)
established for gold
- Hardness
Conversion Conversion Tables Rockwell, Brinell
hardness, Vickers hardness, Rockwell superficial,
Shore Scleroscope
Hardness Testing General Hardness test is
a simple way to verify that a material has been
properly heat-treated.
Heat Treatment of Metals Premium Membership
Required
Heat Treatment and Properties of Iron and Steel
Premium Membership Required
Magnesium Casting Alloys Typical Mechanical
Properties, Elongation, Tensile Temper,
Shear Strength, Hardness, Electrical Conductivity
- Bulk Modulus for Materials Metals and Liquids
Metallurgy Engineering Fundamentals Premium
Membership Required
- Material Tensile Shear and Yield Strength of Engineering Materials Table
- Material Menu
Properties of Metals, Aluminum, Brass, Copper,
Stainless Steel, Tool Steel
- Material
Terms and Definitions Definitions related
to engineering materials and metals.
Metal Melting Temperatures melting point
of a substance depends on pressure
- Natural Stones Physical and Thermal Properties
- Properties
of Metals - Thermal >Metals in general have
high electrical conductivity, high thermal conductivity,
and high density.
Modulus of Elasticity, Average Properties of
Structural Materials, Shear Modulus, Poisson's
Ratio, Density Modulus of Elasticity also
know as Young's Modulus
Modulus of Elasticity, Strength Properties of
Non-Metals Ultimate Strength, Yield Strength
Table of Modulus of Elasticity, Strength Properties
of Non-Metals Ultimate Strength, Yield Strength,
Outgassing rates of aluminium table Outgassing
(also known as offgassing) occurs when gas is
released from adhesives, encapsulants,
lubricants, sealants, and other materials ferrous
and non-ferrous.
Outgassing rates of stainless steels, along
with the surface treatment and pumping time.
Quenching
Review - Heat Treating Quenching - heat
treating
- Relative Density Degrees API and lb/gal. Calculator
- Degrees Baume', Relative Density, lb/gal. Calculator
- Degrees Baume' to Relative Density Calculator
Rockwell Hardness Testing Rockwell hardness
test is the most common method for determining
hardness of metals
Rolling Element Fatigue Testing of Gear Materials
Selection and Use of Engineering Materials
Specific Heat Capacity of Metals Chart specific
heat is the amount of heat energy per unit mass
required to raise the temperature by one degree
Celsius
SAE/AMS Specifications for Solder, Babbitt and
Lead Alloys specifications for soft metals
of Solder, Babbitt and Lead Alloys and Lead,
Tin and Zinc Table
Strength
of Materials Strength / Mechanics of Material
Basics, General Equations and Definitions
Strength Properties of Metals - Iron and Steel
Modulus of Elasticity, Ultimate Strength
ultimate strength, yield point and modulus of
elasticity data for steel and iron
Study of Stiffness, Residual Strength and Fatigue
Life Relationships for Composite Laminates
Tempering
Steel Review Steel is tempered by reheating
after hardening to obtain specific mechanical
properties
Vickers Hardness Testing Vickers Pyramid
Number ( HV ) or Diamond Pyramid Hardness (
DPH ).
Thermal Conductivity Conversions Conversions
Factors for Thermal Conductivity Unit
Thermal Conductivity of Common Metals and Alloys
>typical values of thermal several common commercial
metals and alloys.
Aerospace, Aviation Metals Review Metals
and other materials used within aerospace /
aviation applications
- Specific Heat of Aqueous Solutions of Propylene Glycol
- Thermal Conductivity of Aqueous Solutions of Propylene Glycol
- Viscosity of Aqueous Solutions of Propylene Glycol
Materials Ferrous and Nonferrous
Metals
- Aluminum Electrical Conductors
Stress-Strain Calculator and Plotted Curve Approximation
using Ramberg-Osgood Equation
Atomic Elements Symbols, Atomic Numbers, Weights
and Melting Temperature Points
- Fatigue Design Curves and Analysis for Aluminum
- Aluminum Plate
Aluminum specifications for plate, rounds and
other shapes
Aluminum alloy Basic temper designation and
subdivisions
Aluminum Engineering Properties general
mechanical engineering Properties and data for
many common Aluminum alloys
Aluminum Casting Alloys typical mechanical
characteristics for selected castings.
Mechanical Properties of Aluminum Sand Castings
Cast Aluminum Alloys These are used for parts
of complex shapes by sand casting, permanent
mold casting, and die casting.
- Aluminum
Tempers Basic Aluminum Temper Designations
AISI / SAE Steel Identification Number Chart
AISI / SAE Steel Identification Number Chart.
Carbon Steel Equivalent Designations / Specifications
Common Fiber Composites Engineering Data Table
Densities of Metals and Elements
- Density of Common Engineering Materials and Metals Density is defined as the mass per volume.
Fiberglass Reinforced Thermoplastics Engineering
Design Handbook
Short Fiber Plastic Base Composites Engineering
Design Handbook
Inconel 718 Physical Constants Table Wet
Laminate Carbon Cloth
Inconel Alloys Table Inconel high-strength,
corrosion-resistant nickel chromium material.
Inconel 718 Modulus of Elasticity Table at Low
Temperature Inconel 718 Modulus of Elasticity
Table at Low Temperature
International Specification Designations and
Titles of Hard metals (Cemented Carbides)
Cemented Carbides specifications table
SAE/AMS Specifications for Reactive and Refractory
Alloys
Refractory metals are a group of materials that
includes niobium , tantalum, molybdenum, tungsten,
and rhenium.
- Brass Brass alloys
reference table
- ASTM B601 Temper Designation Codes for Copper and Copper Alloys
- Copper Copper
Plating Specification Mil-C-14550
Copper
UNS Number and Alloys The Unified Numbering
System for Copper
Copper Tubing Size Chart ASTM B88 Dimensions
and Physical Characteristics of Copper Tube:
TYPE K
Copper Tubing HVAC Size Chart Copper Tubing
HVAC Size Table
Copper Tube Size Chart Medical Gas, K and L
Copper Tube: Medical Gas, K and L per. ASTM
B 819.
- Mechanical Properties of Copper Wire
- Stainless
Steel Overview Chemical Composition Chart
Stainless Steel
AISI & UNS Stainless Steel Mechanical Characteristics
typical mechanical characteristics for selected
Stainless Steel
Thermal Linear Expansion of AISI 303 Stainless
Steel AISI 303 stainless steel, which is
a modification of the basic 18-8 austenitic
stainless steel, contains higher amounts of
phosphorous (0.20% max) and sulfur (0.15% min.).
- Steel Overview
carbon and alloy steel references and typical
applications
AISI Steel Mechanical Characteristics - AISI
1015 - AISI 1340 Yield, Tensile, Hardness
AISI 1015 - AISI 1340
4130 - AISI 9310 AISI 3140 - AISI 9310
AISI-SAE Standard Carbon Steels Composition
AISI-SAE 1000-1029 AISI-SAE Standard Carbon
Steels Composition AISI-SAE 1000-1029
AISI-SAE 1039-1095 AISI-SAE Standard Carbon
Steels Composition AISI-SAE 1030-1095
AISI-SAE 1513-1566 AISI-SAE Standard Carbon
Steels Composition AISI-SAE 1513-1566
- Spring
Steel Review Spring steel is generally classified
as a low alloy, medium carbon steel or high
carbon steel with a very high yield strength.
Typical Modulus of Elasticity of Spring Materials
used in Torsion and Tension
Free-Machining Grades — Resulfurized
Free-Machining Grades - Resulfurized & Rephosphorized
Poisson's Ratio Definition & Equation
Poisson's ratio is defined as the negative of
the ratio of the lateral strain to the axial
strain for a uniaxial stress state.
Poisson's Ratio Metals Materials Chart chart
of Poisson's Ratio for common engineering materials
and metals.
- Properties of Molten Metals
- Steel Terms
definitions for a variety of engineering and
manufacturing steel related phrases
Shear Modulus of Rigidity Chart shear modulus
or modulus of rigidity, denoted by G, or sometimes
S or ??, is defined as the ratio of shear stress
to the shear strain:
SAE & AMS Specifications Titanium and Titanium
Alloys Titanium alloys between SAE, Military,
ASTM, ASME, BSI and DIN standards.
Titanium Alloys UNS - AMS - ASTM - ASME - AWS
Cross Ref. #1
Cross Ref. #2
- Tool Steel Material,
Properties and Specifications These tool
steels, which include hot or cold finished bar,
plate, sheet, strip, rod, wire, or forgings,
are normally fabricated into tools, dies, or
fixtures.
Steel - Aluminum - Magnesium - Machinability
Index Chart
Steel Sheet Mechanical Tolerances
Sheet Metal Gauge Tolerances Chart Sheet
- Sheet Metal & Wire
Gauge Sizes Chart Sheet Metal Wire Gauge
Sizes Table Chart
Structural Shapes, Section Sizes Structural
Shapes Steel, Aluminum ASTM, BS, EN, ISO Sizes
Tables
- Weight Mass of Pipe Hollow Cylinder Equation and Calculator
Working Internal Pressure for Copper Tube Solder
or Brazing Joints Based on ASME Standard
B31.9
Rapid Prototype
Wood Engineering Properties
Structural Shape
AISC Ultimate Structural Shapes Properties Viewer
AISC 13th Edition Structural Shapes Properties
Viewer
- Standard Aluminum
Angle Equal Leg shape dimensions, weight
per foot and cross section area for aluminum
angle per ASTM AISC .
- Standard
Aluminum Channel, Standard Aluminum C Channel
per. ASTM C221 size dimensional chart
AISC, ASTM Channel (Steel) ASTM Steel Channel
Section Properties various sizes ranging C3
- C15
AISC, ASTM Wide Flange #1 (Steel) ASTM Steel
Wide Channel H Beam Section Properties various
sizes ranging W4 - W12
AISC, ASTM Wide Flange #2 (Steel) ASTM Steel
sizes ranging W14 - W25
AISC, ASTM S Flange (Steel) Specification
for hot-rolled sections BS 4-1:2005
AISC, ASTM Angle (Steel) #1 ASTM Steel Angle
Section Properties various sizes ranging L2
- L31
AISC, ASTM Angle (Steel) #2 ASTM Steel Angle
Section Properties various sizes ranging L3
- L21
- Standard Aluminum
Angle Unequal Leg ASTM B308 Aluminum Structural
Shape Angle Unequal Legs
- Standard
Aluminum I-Beams Standard Aluminum I-Beam
Size Table Specifications Section Properties
- AISC,
ASTM Steel Angle Unequal Leg size and shape
dimensions, weight per foot and cross section
area for steel angle per AISC.
AISC, ASTM Structural Tees Cut from W Flange
Structural steel AISC A36 Structural Shape Tee
Cut From W Shapes Table Chart.
Rectangle Hollow structural sections (HSS) per
ASTM 1085 Table Chart Rectangle Structural
Tube Per. ASTM 1085
Round Structural Tube Per. ASTM 1085, HSS Hollow
Structural Section Structural Tube ASTM
1085, HSS Hollow Structural Section Round Structural
Tube table chart.
Square Hollow structural sections (HSS) Table
Chart per ASTM 1085 Table Chart ASTM 1085,
table chart HSS Hollow Structural Section Square
Structural Tube.
BS, DIN and ISO Standards
Minimum ultimate tensile loads and proofing
loads BS EN ISO 898-1
BS EN ISO 898-1 Proofing loads ISO metric coarse
pitch thread
BS EN 20898-2 Proof load values - Coarse thread
BS EN ISO 898-6 Proof load values and Minimum
Stripping Strength of nuts
BS ISO EN DIN 20898-7 Mechanical properties
of fasteners: torsional test and minimum
torques for bolts and screws with nominal diameters
1–10 mm
BS EN ISO 10642 Hexagon socket countersunk head
screws
ISO BS EN DIN 4320 Plain Washer, Bright Metric
Series
BS 4320 Plain Washer, Black Metric Series
BS 4464, Single Coil Rectangular Spring Washer,
Metric Series Types B and BP
BS 4464 Double Coil Rectangular Section Spring
Washer: Metric Series, Type D
BS ISO EN 4463 Metric Crinkle Washers Specifications
DIN 6797 Toothed lock washers, metric
DIN 6798 Serrated Lock Washers, Metric
British Association BA Screws Threads tapping
and clearance drills table
Steel Section Properties Chart Narrow I-Beam
BS 4-1 | EN 1993-1-1 Steel Section Properties
and Dimensions Narrow I-Beam Chart | BS 4-1
| EN 1993-1-1.
Steel Section Properties Chart Wide I-Beam BS
and Dimensions Wide I-Beam Chart | BS 4-1 |
EN 1993-1-1
Structural Steel Angle Section Properties, Unequal
Leg BSI BS EN 10056 Structural Steel Angle
Section Properties, Unequal Leg BSI BS EN 1005
Structural Steel Angle Section Properties, Equal
Leg BSI BS EN 10056 Tolerances for equal
and unequal leg angles are given in EN 10056-2.
- Square Universal Hollow Tube Sections Hot-Finished per BS EN 10365 Euro Code 3 Section Properties Calculator
- Circular Hollow Tube Sections Cold-Formed per BS EN 10365 Euro Code 3 Section Properties Calculator
- Elliptical Hollow Tube Section Properties Calculator
- Circular Hollow Tube Universal Section Properties Calculator
- Rectangular Hollow Tube Section Properties Calculator
- Universal Tees (T) Split from UC per BS EN 10365 Euro Code 3 Section Properties Calculator
- Universal Tees (T) Split from Universal Beams Calculator
- Universal Back to Back Unequal L Angles (L) Section Properties Calculator
- Universal Back to Back Equal L Section Properties Calculator
- Universal Unequal leg Angles (L) per. BS EN 10365 Euro Code 3 Section Properties Calculator
- Universal Equal leg Angles (L) per. BS EN 10365 Euro Code 3 Section Properties Calculator
- Universal Parallel Flange Channels Properties Calculator
Structural Steel I-Beam Universal Flange Section
Properties BS 4-1:2005 BS 4-1:2005 specifies
the dimensions and mass of the following hot-rolled
structural steel sections: Sizes 203 to 914
Properties BS4: Part 1: 1993 BS4: Part 1
| European Standard Wide Flange H Beam.
Thermal Electrical Properties Table Chart Iron
per BS2789 thermal and electrical properties
of ductile iron grades covered UK specification
BS2789.
ISO Stress Area Equation and Calculator
- Proof load values are given in BS EN 20898-2:
T-Slot Profile Design per. BS 2485
- T-Bolts
and T-Nuts Dimensions per. BS 2485
- Universal Narrow Beams Engineering Data Calculator
- Universal Columns Section Properties Calculator
- Universal Bearing Piles Section Properties Calculator
SST ASIC Structural Shapes
Commercial Manufacturing Materials
Indian Standards Per. IS 808
Graphite Products
Advanced Composites, Design and Applications
Composites Materials Handbook, Volume 1
Design Guidelines for Characterizations of Structural
Materials
Composites Materials Handbook, Volume 2
Composite Material Properties
Composites Materials Handbook, Volume 3
Material Usage, Design and Analysis
Composites Materials Handbook, Volume 4
Metal Matrix Composites
Composites Materials Handbook, Volume 5
Ceramic Matrix Composites
Bolted and Bonded Joints in Polymeric Composites
Fibrous Composites, Design and Analysis
Graphite Electrodes Graphite electrodes
are used primarily in electric arc furnace steel
manufacturing.
Graphite
Blocks and Rounds Graphite Blocks and Rounds
Application Review
Gouging Rods Gouging rods are used for cutting,
welding, removing metal defects, inspection
of welds and removing excessive welds.
NEMA and IEC Standard Taper and Connection Sizes
for Graphite / Carbon Electrodes NEMA &
IEC 3, 4 TPI Taper standards, and male / female
size connection sizes
Specialty Graphite Review Specialty or custom
graphite materials and shapes are available
within industry.
Misc. Engineering Materials
Activated
Carbon Activated Carbon Industrial Applications
Review:
- AGMA Allowable Contact Stress, sac, for Steel Gears Table The allowable stress numbers for gear materials vary with items such as material composition, cleanliness, residual stress, microstructure, quality, heat treatment, and processing practices. For materials other than steel, a range is shown, and the lower values should be used for general design purposes.
- AGMA Major metallurgical factors affecting the allowable contact stress number, sac, and allowable bending stress number
Composite Engineering Materials Review composite
is a material consisting of two (or more) different
materials bonded together, one forming a ???matrix'
Bolted Joints in Composites Structures Design
Guide - This design guide was prepared under
Contract, titled "Bolted Joints in Composite
Structures: Design, Analysis and Verification,"
and administered by the Air Force Wright Aeronautical
Laboratories.
- Chemical Elements Atomic Weight Valence and Number
DIY Face Masks Design Materials for COVID-19
Virus Ideally, a N95 respirator performance
would be your goal, however the availability
of these face mask respirators can be limited
in today' COVID-19 pandemic.
Laminated Glass Cloth Engineering Properties
Wet Laminate Glass Cloth engineering properties
in imperial units.
Pre-Pregnated Carbon Cloth Engineering Properties
Imperial Units
Wet Laminate Carbon Cloth engineering properties
in both SI and imperial units.
Wet Laminate Carbon Tape Engineering Properties
Wet Laminate Carbon Tape engineering properties
Graphite Review Graphite is a very good
engineering material for high temperature, high-pressure
transfer of liquids
Graphite
Blocks, Rounds Review Graphite blocks are
available in various sizes and grades.
Graphite Cathode Blocks Review Graphite
Cathode blocks are produced by and processed
by vibrating-molding machine or extrusion die
machine.
Graphene Review Graphene is an allotrope
of carbon, whose structure is one-atom-thick
planar sheets of sp2-bonded carbon atoms
Periodic Table of Elements Periodic Table
of Elements Atomic Properties of the Elements
- Reference NIST
Phenolic Plastics Engineering Data Table
Phenolic Plastics Engineering Specifications
and Engineering Data
- Solubility of Inorganic Substances in Water
- Solubility of Gases in Water
- Structural Composite Sandwich Design and Analysis in Aerospace Applications
Heat Treating
Polymers - Plastics
