Brinell and Rockwell Hardness Conversion Table Chart
These Conversion Tables presents data in the Rockwell A, B, C, D, E and F hardness range on the relationship among Brinell hardness, Vickers hardness, Rockwell superficial, hardness, and Shore Scleroscope hardness of nonaustenitic steels including carbon, alloy, and tool steels in the as-forged, annealed, normalized, and quenched and tempered conditions provided that they are homogeneous.
For plain carbon steels, the approximate relationship between the hardness and tensile strength is:
Tensile strength = Bhn × 515 (for Brinell numbers up to 175)
Tensile strength = Bhn × 490 (for Brinell numbers larger than 175)
The above formulas give the tensile strength in pounds per square inch for steels. These approximate relationships between hardness and tensile strength do not apply to nonferrous metals, with the possible exception of certain aluminum alloys.
Brinell Hardness Testing Equation
Table A
Brinell Hardness to Rockwell Hardness Conversion Table
Brinell Hardness Rockwell Hardness Tensile Strength
(Approximate)
Psi
Tungsten Carbide
Ball 3000 KG
A Scale 60KG B Scale 100KG C Scale 150KG
- 85.6 - 68.0 -
- 85.3 - 67.5 -
- 85.0 - 67.0 -
767 84.7 - 66.4 -
757 84.4 - 65.9 -
745 84.1 - 65.3 -
733 83.8 - 64.7 -
722 83.4 - 64.0 -
712 - - - -
710 83.0 - 63.3 -
698 82.6 - 62.5 -
684 82.2 - 61.8 -
682 82.2 - 61.7 -
670 81.8 - 61.0 -
656 81.3 - 60.1 -
653 81.2 - 60.0 -
647 81.1 - 59.7 -
638 80.8 - 59.2 329,000
630 80.6 - 58.8 324,000
627 80.5 - 58.7 323,000
601 79.8 - 57.3 309,000
578 79.1 - 56.0 297,000
555 78.4 - 54.7 285,000
534 77.8 - 53.5 274,000
514 76.9 - 52.1 263,000
495 76.3 - 51.0 253,000
477 75.6 - 49.6 243,000
461 74.9 - 48.5 235,000
444 74.2 - 47.1 225,000
429 73.4 - 45.7 217,000
415 72.8 - 44.5 210,000
401 72.0 - 43.1 202,000
388 71.4 - 41.8 195,000
375 70.6 - 40.4 188,000
363 70.0 - 39.1 182,000
352 69.3 - 37.9 176,000
341 68.7 - 36.6 170,000
331 68.1 - 35.5 166,000
321 67.5 - 34.3 160,000
311 66.9 - 33.1 155,000
302 66.3 - 32.1 150,000
293 65.7 - 30.9 145,000
285 65.3 - 29.9 141,000
277 64.6 - 28.8 137,000
269 64.1 - 27.6 133,000
262 63.6 - 26.6 129,000
255 63.0 - 25.4 126,000
248 62.5 - 24.2 122,000
241 61.8 100.0 22.8 118,000
235 61.4 99.0 21.7 115,000
229 60.8 98.2 20.5 111,000
223 - 97.3 20.0 -
217 - 96.4 18.0 105,000
212 - 95.5 17.0 102,000
207 - 94.6 16.0 100,000
201 - 93.8 15.0 98,000
197 - 92.8 - 95,000
192 - 91.9 - 93,000
187 - 90.7 - 90,000
183 - 90.0 - 89,000
179 - 89.0 - 87,000
174 - 87.8 - 85,000
170 - 86.8 - 83,000
167 - 86.0 - 81,000
163 - 85.0 - 79,000
156 - 82.9 - 76,000
149 - 80.8 - 73,000
143 - 78.7 - 71,000
137 - 76.4 - 67,000
131 - 74.0 - 65,000
126 - 72.0 - 63,000
121 - 69.8 - 60,000
116 - 67.6 - 58,000
111 - 65.7 - 56,000
Table B
Rockwell - Rockwell Superficial - Brinell - Vickers - Shore Hardness Conversion
Rockwell
Brinell
Vickers
Shore Hardness
A
B
C
D
E
F
15-N
30-N
45-N
30-T
3000 kg
500 kg
136
60kg Brale
100kg 1/16" Ball
150kg Brale
100kg Brale
100kg 1/8" Ball
60kg 1/16" Ball
15kg Brale
30kg Brale
45kg Brale
30 kg 1/16" Ball
10mm Ball Steel
10mm Ball Steel
Diamond Pyramid
Sciero-scope
86.5
70
78.5
94.0
86.0
77.6
1076
101
86.0
69
77.7
93.5
85.0
76.5
1044
99
85.6
68
76.9
93.2
84.4
75.4
940
97
85.0
67
76.1
92.9
83.6
74.2
900
95
84.5
66
75.4
92.5
82.8
73.2
865
92
83.9
65
74.5
92.2
81.9
72.0
739
832
91
83.4
64
73.8
91.8
81.1
71.0
722
800
88
82.8
63
73.0
91.4
80.1
69.9
705
772
87
82.3
62
72.2
91.1
79.3
68.8
688
746
85
81.8
61
71.5
90.7
78.4
67.7
670
720
83
81.2
60
70.7
90.2
77.5
66.6
654
697
81
80.7
59
69.9
89.8
76.6
65.5
634
674
80
80.1
58
69.2
89.3
75.7
64.3
615
653
78
79.6
57
68.5
88.9
74.8
63.2
595
633
76
79.0
56
67.7
88.3
73.9
62.0
577
613
75
78.5
120
55
66.9
87.9
73.0
60.9
560
595
74
78.0
120
54
66.1
87.4
72.0
59.8
543
577
72
77.4
119
53
65.4
86.9
71.2
58.6
525
560
71
76.8
119
52
64.6
86.4
70.2
57.4
500
544
69
76.3
118
51
63.8
85.9
69.4
56.1
487
528
68
75.9
117
50
63.1
85.5
68.5
55.0
475
513
67
75.2
117
49
62.1
85.0
67.6
53.8
464
498
66
74.7
116
48
61.4
84.5
66.7
52.5
451
484
64
74.1
116
47
60.8
83.9
65.8
51.4
442
471
63
73.6
115
46
60.0
83.5
64.8
50.3
432
458
62
73.1
115
45
59.2
83.0
64.0
49.0
421
446
60
72.5
114
44
58.5
82.5
63.1
47.8
409
434
58
72.0
113
43
57.7
82.0
62.2
46.7
400
423
57
71.5
113
42
56.9
81.5
61.3
45.5
390
412
56
70.9
112
41
56.2
80.9
60.4
44.3
381
402
55
70.4
112
40
55.4
80.4
59.5
43.1
371
392
54
69.9
111
39
54.6
79.9
58.6
41.9
362
382
52
69.4
110
38
53.8
79.4
57.7
40.8
353
372
51
68.9
110
37
53.1
78.8
56.8
39.6
344
363
50
68.4
109
36
52.3
78.3
55.9
38.4
336
354
49
67.9
109
35
51.5
77.7
55.0
37.2
327
345
48
67.4
108
34
50.8
77.2
54.2
36.1
319
336
47
66.8
108
33
50.0
76.6
53.3
34.9
311
327
46
66.3
107
32
49.2
76.1
52.1
33.7
301
318
44
65.8
106
31
48.4
75.6
51.3
32.5
294
310
43
65.3
105
30
47.7
75.0
50.4
31.3
286
302
42
64.7
104
29
47.0
74.5
49.5
30.1
279
294
41
64.3
104
28
46.1
73.9
48.6
28.9
271
286
41
63.8
103
27
45.2
73.3
47.7
27.8
264
279
40
63.3
103
26
44.6
72.8
46.8
26.7
258
272
39
62.8
102
25
43.8
72.2
45.9
25.5
253
266
38
62.4
101
24
43.1
71.6
45.0
24.3
247
260
37
62.0
100
23
42.1
71.0
44.0
23.1
82.0
240
201
254
36
61.5
99
22
41.6
70.5
43.2
22.0
81.5
234
195
248
35
61.0
98
21
40.9
69.9
42.3
20.7
81.0
228
189
243
35
60.5
97
20
40.1
69.4
41.5
19.6
80.5
222
184
238
34
59.0
96
18
80.0
216
179
230
33
58.0
95
16
79.0
210
175
222
32
57.5
94
15
78.5
205
171
213
31
57.0
93
13
78.0
200
167
208
30
56.5
92
12
77.5
195
163
204
29
56.0
91
10
77.0
190
160
196
28
55.5
90
9
76.0
185
157
192
27
55.0
89
8
75.5
180
154
188
26
54.0
88
7
75.0
176
151
184
26
53.5
87
6
74.5
172
148
180
26
53.0
86
5
74.0
169
145
176
25
52.5
85
4
73.5
165
142
173
25
52.0
84
3
73.0
162
140
170
25
51.0
83
2
72.0
159
137
166
24
50.5
82
1
71.5
156
135
163
24
50.0
81
0
71.0
153
133
160
24
49.5
80
70.0
150
130
49.0
79
69.5
147
128
48.5
78
69.0
144
126
48.0
77
68.0
141
124
47.0
76
67.5
139
122
46.5
75
99.5
67.0
137
120
46.0
74
99.0
66.0
135
118
45.5
73
98.5
65.5
132
116
45.0
72
98.0
65.0
130
114
44.5
71
100.0
97.5
64.2
127
112
44.0
70
99.5
97.0
63.5
125
110
43.5
69
99.0
96.0
62.8
123
109
43.0
68
98.0
95.5
62.0
121
107
42.5
67
97.5
95.0
61.4
119
106
42.0
66
97.0
94.5
60.5
117
104
41.8
65
96.0
94.0
60.1
116
102
41.5
64
95.5
93.5
59.5
114
101
41.0
63
95.0
93.0
58.7
112
99
40.5
62
94.5
92.0
58.0
110
98
40.0
61
93.5
91.5
57.3
108
96
39.5
60
93.0
91.0
56.5
107
95
39.0
59
92.5
90.5
55.9
106
94
38.5
58
92.0
90.0
55.0
104
92
38.0
57
91.0
89.5
54.6
102
91
37.8
56
90.5
89.0
54.0
101
90
37.5
55
90.0
88.0
53.2
99
89
37.0
54
89.5
87.5
52.5
87
36.5
53
89.0
87.0
51.8
86
36.0
52
88.0
86.5
51.0
85
35.5
51
87.5
86.0
50.4
84
35.0
50
87.0
85.5
49.5
83
34.8
49
86.5
85.0
49.1
82
34.5
48
85.5
84.5
48.5
81
34.0
47
85.0
84.0
47.7
80
33.5
46
84.5
83.0
47.0
79
33.0
45
84.0
82.5
46.2
79
32.5
44
83.5
82.0
45.5
78
32.0
43
82.5
81.5
44.8
77
31.5
42
82.0
81.0
44.0
76
31.0
41
81.5
80.5
43.4
75
30.8
40
81.0
79.5
43.0
74
30.5
39
80.0
79.0
42.1
74
30.0
38
79.5
78.5
41.5
73
29.5
37
79.0
78.0
40.7
72
29.0
36
78.5
77.5
40.0
71
28.5
35
78.0
77.0
39.3
71
28.0
34
77.0
76.5
38.5
70
27.8
33
76.5
75.5
37.9
69
27.5
32
76.0
75.0
37.5
68
27.0
31
75.5
74.5
36.6
68
26.5
30
75.0
74.0
36.0
67
26.0
29
74.0
73.5
35.2
66
25.5
28
73.5
73.0
34.5
66
25.0
27
73.0
72.5
33.8
65
24.5
26
72.5
72.0
33.1
65
24.2
25
72.0
71.0
32.4
64
24.0
24
71.0
70.5
32.0
64
23.5
23
70.5
70.0
31.1
63
23.0
22
70.0
69.5
30.4
63
22.5
21
69.5
69.0
29.7
62
22.0
20
68.5
68.5
29.0
62
21.5
19
68.0
68.0
28.1
61
21.2
18
67.5
67.0
27.4
61
21.0
17
67.0
66.5
26.7
60
20.5
16
66.5
66.0
26.0
60
20.0
15
65.5
65.5
25.3
59
14
65.0
65.0
24.6
59
13
64.5
64.5
23.9
58
12
64.0
64.0
23.5
58
11
63.5
63.5
22.6
57
10
62.5
63.0
21.9
57
9
62.0
62.0
21.2
56
8
61.5
61.5
20.5
56
7
61.0
61.0
19.8
56
6
60.5
60.5
19.1
55
5
60.0
60.0
18.4
55
4
59.0
59.5
18.0
55
3
58.5
59.0
17.1
54
2
58.0
58.0
16.4
54
1
57.5
57.5
15.7
53
0
57.0
57.0
15.0
53
www.engineersedge.com
Advertising | Contact
