General Engineering and Design Data and Information
Engineering Application & Design
Engineering Fundamentals | Engineering Materials
Engineering Analysis
- The following are to links to General engineering and Design resources, tools, articles and other useful data.
- Should you find any errors omissions broken links, please let us know - Feedback
- Do you want to contribute to this section? See Premium Publisher Program
- Allen Hexagon Tools Inch Size Table, Hex Key, Hexagon Keys Inch Series Tools
- Allen Hexagon Tools Metric Size Table, Hex Key, Hexagon Keys Metric Series Tools
- Bolt / Stud / Fastener Tensioner Application and About
- Boiling Pressure H2O in Vacuum
- Copper Wire AWG
- Design of Food Processing Equipment Review
- Driveline Design
- Electrical Equations
- Electric Motor Terms and Definitions
- Engine Formula (4-Stroke)
- Gasket Compression and Fastener Spacing Design
- Grease and Oil Traps Review
- Industrial Brushes Application and Review
- Key and Spline Drive Bit Tool Size Table per. ASME B18.3
- Mechanisms in Modern Engineering Design - A Handbook for Engineers, Designers, and Inventors Premium Membership Required
- Rivet Installation & Application
- Wire Gages
- SAE 12 Point Box Wrench Installtion Design Clearance Sizes
- Saturation Pressure and Temperature for Water Table Calculator
- Standard Square Drives for Socket Tools ASA B5.38 1958
- Open End Engineers Wrench 15° Installation Design Clearance Sizes
- Water and Oil Separator Review
- Universal Joint Design and Engineering Equations
O-Rings / Elastomers
- Analysis of large-sized O-rings used in pressure chambers
- Mechanical Seal Balance Ratio Formula and Calculator
- Specification for Rubber Gaskets Free Membership Required
- Rubber Molding Design Guidelines and Review
- Poppet Seal Gasket Oring Operating Life and Reliability Equations and Calculator
- Groove Design for Metric ISO Size O-Rings per. ISO 3601-2
- O-Ring, Design Considerations General
- O-Ring Installation, Design & Specification Gland (Groove) Sizes Static Cylindrical Applications
- O-Ring Installation, Design & Specification Gland (Groove) Sizes Static Flange Application
- O-Ring Installation Design & Specification For Dynamic / Reciprocating Applications
- O-Ring Installation Compressive Load vs Hardness Chart .070 Diameter ORing
- O-Ring Installation Compressive Load vs Hardness Chart .103 Diameter ORing
- O-Ring Installation Compressive Load vs Hardness Chart .139 Diameter ORing
- O-Ring Installation Compressive Load vs Hardness Chart .210 Diameter ORing
- O-Ring Installation Compressive Load vs Hardness Chart .275 Diameter ORing
