O-Ring Installation Compressive Load vs Hardness Chart .103 Diameter O-Ring
The following chart gives the load required to compress a .103 diameter o-ring with respect to percent compression of diameter and the applicable hardness - Shore A scale.
To use the chart, first determine the o-ring diameter, material hardness, then your design compression on the o-ring. With this you can determine the estimated compression force per linear inch of your installed o-ring.
Click on below image to enlarge
References: Parker-Hannifin, Chrometrics, DuPont
- Rubber Molding Design Guidelines and Review
- O-Ring, Design Considerations General
- O-Ring Installation, Design & Specification Gland (Groove) Sizes Static Cylindrical Applications
- O-Ring Installation, Design & Specification Gland (Groove) Sizes Static Flange Application
- O-Ring Installation Design & Specification For Dynamic / Reciprocating Applications
- O-Ring Installation Compressive Load vs Hardness Chart .070 Diameter ORing
- O-Ring Installation Compressive Load vs Hardness Chart .139 Diameter ORing
- O-Ring Installation Compressive Load vs Hardness Chart .210 Diameter ORing
- O-Ring Installation Compressive Load vs Hardness Chart .275 Diameter ORing
