Open End Engineers Wrench 15° Installation Design Clearance Sizes Table Chart
General Engineering Reviews
Open End Engineers Wrench 15° Installation Design Clearance Sizes - Wrench Clearance Chart data derived from SAE drafting manual and ANSI/ASME B18.2.2-1987 (R1999) wrench opining for nuts/bolts. This represents the recommended installation clearances for standard 15 degree open end wrenches.
Wrench installation Clearance
90 Deg
ree Installation
120 Degrees Wrench Installtion
120 Degree + Installation
Note: All dimensions are in inches
Wrench Size
Bolt Center Wall Clearance Minimum
A
Wall Radius Maximum
B
Minimum Bolt Spacing
C
D
.156
.220
.250
.390
.160
.188
.250
.280
.430
.190
.250
.280
.340
.530
.270
.312
.380
.470
.660
.280
.344
.420
.500
.750
.340
.375
.420
.500
.780
.360
.438
.470
.590
.890
.420
.500
.520
.640
1.000
.470
.562
.590
.770
1.130
.520
.594
.640
.830
1.210
.530
.625
.640
.830
1.230
.550
.688
.770
.920
1.470
.660
.750
.770
.920
1.510
.670
.781
.830
.950
1.550
.690
.812
.910
1.120
1.660
.720
.875
.970
1.150
1.810
.800
.938
.970
1.150
1.850
.810
1.000
1.050
1.230
2.000
.880
1.062
1.090
1.250
2.100
.970
1.125
1.140
1.370
2.210
1.000
1.250
1.270
1.420
2.440
1.080
1.312
1.390
1.690
2.630
1.170
1.438
1.470
1.720
2.800
1.250
1.500
1.470
1.720
2.840
1.270
1.625
1.560
1.880
3.100
1.380
Wrench Size
E
Wall Radius Maximum
F
Reference Wrench End Clearance
G
Wrench Thickness or Width Maximum
H
.156
.250
.200
.030
.094
.188
.270
.230
.030
.172
.250
.310
.310
.030
.172
.312
.390
.390
.050
.203
.344
.450
.450
.050
.203
.375
.450
.520
.050
.219
.438
.520
.640
.050
.250
.500
.580
.660
.050
.266
.562
.660
.700
.050
.297
.594
.700
.700
.050
.344
.625
.700
.700
.050
.344
.688
.880
.800
.060
.375
.750
.880
.800
.060
.375
.781
.890
.840
.060
.375
.812
.970
.860
.060
.406
.875
1.060
.910
.060
.438
.938
1.060
.950
.060
.438
1.000
1.160
1.060
.060
.500
1.062
1.200
1.200
.080
.500
1.125
1.270
1.230
.080
.500
1.250
1.390
1.310
.080
.562
1.312
1.520
1.340
.080
.562
1.438
1.590
1.340
.090
.641
1.500
1.590
1.450
.090
.641
1.625
1.750
1.560
.090
.641
