Design Guidelines for Drive Shaft Installation Angle
General Engineering Reviews | Engineering Applications and Design
When designing or modifying a automotive, truck or other vehicle drive line (drive shaft) it is very important to understand the application and philosophy behind calculating drive line angles. There are a number of highly technical mathematical equations that are required to determine the precise angles of the drive line.
When determining the optimum drive line angles for a vehicle, a good rule of thumb to follow is the six to one-and-a-half rule. The drive line working angle should not exceed six degrees, and the adjoining u-joints at either end of a shaft should be different by no more than one-and-a-half degrees. When u-joints are arranged this way, the angles are said to be "canceled."
Designers should remember that if the six to one-and-a-half degree angle boundaries are exceeded, the u-joint is working in unfamiliar, undesirable territory, resulting in drive line, and potentially, drive train problems.
Generally speaking, if a drive line is used in low speed applications, the angles can be higher. On the other hand, great care must be exercised with higher speed applications to keep the angles below the recommended residual angles.
To calculate the residual angles of the drive line, operators can refer to Society of Automotive Engineers (SAE) publication AE-7 (Section 3.1.1, Cardan or Hooke Universal Joint).
For vehicles equipped with a two-joint drive line system, the following chart can be a helpful aid in determining the optimum operating angles.
Between Joint Angles For Two-Joint System
Drive line RPM |
Angle of joint #1 | |||||||||
0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | |
Allowable Angles of joint #2 | ||||||||||
1500 | 7.3 | 7.4 | 7.6 | 7.9 | 8.3 | 8.9 | 9.5 | 10.1 | 10.8 | 11.6 |
1600 | 6.9 | 6.9 | 7.1 | 7.5 | 7.9 | 8.5 | 9.1 | 9.8 | 10.5 | |
1700 | 6.5 | 6.5 | 6.8 | 7.1 | 7.6 | 8.2 | 8.8 | 9.5 | ||
1800 | 6.1 | 6.2 | 6.4 | 6.8 | 7.3 | 7.9 | 8.5 | 9.3 | ||
1900 | 5.8 | 5.9 | 6.1 | 6.5 | 7.0 | 7.6 | 8.3 | 9.1 | ||
2000 | 5.5 | 5.6 | 5.8 | 6.2 | 6.8 | 7.4 | 8.1 | |||
2100 | 5.2 | 5.3 | 5.6 | 6.0 | 6.6 | 7.2 | 8.0 | |||
2200 | 5.0 | 5.1 | 5.4 | 5.8 | 6.4 | 7.1 | 7.8 | |||
2300 | 4.8 | 4.9 | 5.2 | 5.6 | 6.2 | 6.9 | ||||
2400 | 4.6 | 4.7 | 5.0 | 5.5 | 6.1 | 6.8 | ||||
2500 | 4.4 | 4.5 | 4.8 | 5.3 | 5.9 | 6.6 | ||||
2600 | 4.2 | 4.3 | 4.7 | 5.2 | 5.8 | 6.5 | ||||
2700 | 4.1 | 4.2 | 4.5 | 5.0 | 5.7 | |||||
2800 | 3.9 | 4.0 | 4.4 | 4.9 | 5.6 | |||||
2900 | 3.8 | 3.9 | 4.3 | 4.8 | 5.5 | |||||
3000 | 3.7 | 3.8 | 4.2 | 4.7 | 5.4 | |||||
3100 | 3.5 | 3.7 | 4.1 | 4.6 | 5.3 | |||||
3200 | 3.4 | 3.6 | 4.0 | 4.6 | 5.3 | |||||
3300 | 3.3 | 3.5 | 3.9 | 4.5 | 5.2 | |||||
3400 | 3.2 | 3.4 | 3.8 | 4.4 |
To use the above chart:
- Find the RPM speed of the drive line.
- Next find the lower joint angle which is along the top of the chart from
left to right.
- Then, look up the maximum allowable second joint angle next to the speed.
