Related Resources: fluid flow
Copper Tubing Size Chart ASTM B-88
Hydraulic, Pneumatic Design & Engineering | Fluid Power Engineering
Design specifications for Copper tube, tubing types and standards based on ASTM B88, Type K, L, and M size, wall thickness and weight specifications. Copper tubing size chart.
Dimensions and Physical Characteristics of Copper Tube: TYPE K
Nominal Size inches |
Outside Diameter |
Inside Diameter |
Wall Thickness |
Calculated Values (based on nominal dimensions) |
Area of Bore, sq inches |
Weight of Tube Only, pounds/linear ft |
Cross Weigh of Tube & Water, pounds/linear ft |
Contents of Tube per linear ft |
Cu ft |
Gal |
1/4 |
.375 |
.305 |
.035 |
.073 |
.145 |
.177 |
.00051 |
.00379 |
3/8 |
.500 |
.402 |
.049 |
.127 |
.269 |
.324 |
.00088 |
.00660 |
1/2 |
.625 |
.527 |
.049 |
.218 |
.344 |
.438 |
.00151 |
.0113 |
5/8 |
.750 |
.652 |
.049 |
.334 |
.418 |
.562 |
.00232 |
.0174 |
3/4 |
.875 |
.745 |
.065 |
.436 |
.641 |
.829 |
.00303 |
.0227 |
1 |
1.125 |
.995 |
.065 |
.778 |
.839 |
1.18 |
.00540 |
.0404 |
1 1/4 |
1.375 |
1.245 |
.065 |
1.22 |
1.04 |
1.57 |
.00847 |
.0634 |
1 1/2 |
1.625 |
1.481 |
.072 |
1.72 |
1.36 |
2.10 |
.0119 |
.0894 |
2 |
2.125 |
1.959 |
.083 |
3.01 |
2.06 |
3.36 |
.0209 |
.156 |
2 1/2 |
2.625 |
2.435 |
.095 |
4.66 |
2.93 |
4.94 |
.0324 |
.242 |
3 |
3.125 |
2.907 |
.109 |
6.64 |
4.00 |
6.87 |
.0461 |
.345 |
3 1/2 |
3.625 |
3.385 |
.120 |
9.00 |
5.12 |
9.01 |
.0625 |
.468 |
4 |
4.125 |
3.857 |
.134 |
11.7 |
6.51 |
11.6 |
.0813 |
.608 |
5 |
5.125 |
4.805 |
.160 |
18.1 |
9.67 |
17.5 |
.126 |
.940 |
6 |
6.125 |
5.741 |
.192 |
25.9 |
13.9 |
25.1 |
.180 |
1.35 |
8 |
8.125 |
7.583 |
.271 |
45.2 |
25.9 |
45.4 |
.314 |
2.35 |
10 |
10.125 |
9.449 |
.338 |
70.1 |
40.3 |
70.6 |
.487 |
3.64 |
12 |
12.125 |
11.315 |
.405 |
100.55 |
57.8 |
101 |
.701 |
5.25 |
Dimensions and Physical Characteristics of Copper Tube: TYPE L
Nominal or Standard Size, inches |
Nominal Dimensions, inches |
Outside Diameter |
Inside Diameter |
Wall Thickness |
Cross Sectional Area of Bore, sq inches |
Weight of Tube & Water, pounds/per linear ft |
Cu ft |
Gal |
1/4 |
.375 |
.315 |
.030 |
.078 |
.126 |
.160 |
.00054 |
.00405 |
3/8 |
.500 |
.430 |
.035 |
.145 |
.198 |
.261 |
.00101 |
.00753 |
1/2 |
.625 |
.545 |
.040 |
.233 |
.285 |
.386 |
.00162 |
.0121 |
5/8 |
.750 |
.666 |
.042 |
.348 |
.362 |
.506 |
.00232 |
.0174 |
3/4 |
.875 |
.785 |
.045 |
.484 |
.455 |
.664 |
.00336 |
.0251 |
1 |
1.125 |
1.025 |
.050 |
.825 |
.655 |
1.01 |
.00573 |
.0429 |
1 1/4 |
1.375 |
1.265 |
.055 |
1.26 |
.884 |
1.43 |
.00875 |
.0655 |
1 1/2 |
1.625 |
1.505 |
.060 |
1.78 |
1.14 |
1.91 |
.0124 |
.0925 |
2 |
2.125 |
1.985 |
.070 |
3.09 |
1.75 |
3.09 |
.0215 |
.161 |
2 1/2 |
2.625 |
2.465 |
.080 |
4.77 |
2.48 |
4.54 |
.0331 |
.248 |
3 |
3.125 |
2.945 |
.090 |
6.81 |
3.33 |
6.27 |
.0473 |
.354 |
3 1/2 |
3.625 |
3.425 |
.100 |
9.21 |
4.29 |
8.27 |
.0640 |
.478 |
4 |
4.125 |
3.905 |
.110 |
12.0 |
5.38 |
10.1 |
.0764 |
.571 |
5 |
5.125 |
4.875 |
.125 |
18.7 |
7.61 |
15.7 |
.130 |
.971 |
6 |
6.125 |
5.845 |
.140 |
26.8 |
10.2 |
21.8 |
.186 |
1.39 |
8 |
8.125 |
7.725 |
.200 |
46.9 |
19.3 |
39.6 |
.326 |
2.44 |
10 |
10.125 |
9.625 |
.250 |
72.8 |
30.1 |
61.6 |
.506 |
3.78 |
12 |
12.125 |
11.565 |
.280 |
105 |
40.4 |
85.8 |
.729 |
5.45 |
Dimensions and Physical Characteristics of Copper Tube: TYPE M
Calculated Values (based on nominal size) |
Nominal inches |
Outside Diameter |
Inside Diameter |
Wall Thickness |
Weight Tube Only, pounds per linear ft |
Weight Tube & Water pounds per linear ft |
Cu ft |
Gal |
3/8 |
.500 |
.450 |
.025 |
.159 |
.145 |
.214 |
.00110 |
.00826 |
1/2 |
.625 |
.569 |
.028 |
.254 |
.204 |
.314 |
.00176 |
.0132 |
3/4 |
.875 |
.811 |
.032 |
.517 |
.328 |
.551 |
.00359 |
.0269 |
1 |
1.125 |
1.055 |
.035 |
.874 |
.465 |
.843 |
.00607 |
.0454 |
1 1/4 |
1.375 |
1.291 |
.042 |
1.31 |
.682 |
1.25 |
.00910 |
.0681 |
1 1/2 |
1.625 |
1.527 |
.049 |
1.83 |
.940 |
1.73 |
.0127 |
.0951 |
2 |
2.125 |
2.009 |
.058 |
3.17 |
1.46 |
2.83 |
.0220 |
.165 |
2 1/2 |
2.625 |
2.495 |
.065 |
4.89 |
2.03 |
4.14 |
.0340 |
.254 |
3 |
3.125 |
2.981 |
.072 |
6.98 |
2.68 |
5.70 |
.0485 |
.363 |
3 1/2 |
3.625 |
3.459 |
.083 |
9.40 |
3.58 |
7.64 |
.0653 |
.488 |
4 |
4.125 |
3.935 |
.095 |
12.2 |
4.66 |
9.83 |
.0847 |
.634 |
5 |
5.125 |
4.907 |
.109 |
18.9 |
6.66 |
14.8 |
.131 |
.982 |
6 |
6.125 |
5.881 |
.122 |
27.2 |
8.92 |
20.7 |
.189 |
1.41 |
8 |
8.125 |
7.785 |
.170 |
47.6 |
16.5 |
37.1 |
.331 |
2.47 |
10 |
10.125 |
9.701 |
.212 |
73.9 |
25.6 |
57.5 |
.513 |
3.84 |
12 |
12.125 |
11.617 |
.254 |
106 |
36.7 |
82.5 |
.736 |
5.51 |
Dimensions and Physical Characteristics of Copper Tube: DWV (Drain, Waste and Vent)
Nominal, inches |
Nominal Size, inches | Calculated Values (based on nominal size) | ||||||
Outside Diameter |
Inside Diameter |
Wall Thickness |
Weight of Tube & Water, pounds/linear ft |
Cu ft | Gal | |||||||
1 1/4 |
1.375 |
1.295 |
.040 |
1.32 |
.650 |
1.22 |
.00917 |
.0686 |
1 1/2 |
1.625 |
1.541 |
.042 |
1.87 |
.809 |
1.62 |
.0130 |
.0971 |
2 |
2.125 |
2.041 |
.042 |
3.27 |
1.07 |
2.48 |
.0227 |
.170 |
3 |
3.125 |
3.030 |
.045 |
7.21 |
1.69 |
4.81 |
.0501 |
.375 |
4 |
4.125 |
4.009 |
.058 |
11.6 |
2.87 |
7.88 |
.0806 |
.603 |
5 |
5.125 |
4.981 |
.072 |
19.5 |
4.43 |
12.9 |
.135 |
1.01 |
6 |
6.125 |
5.959 |
.083 |
27.9 |
6.10 |
18.2 |
.194 |
1.45 |
8 |
8.125 |
7.907 |
.109 |
49.1 |
10.6 |
31.8 |
.341 |
2.55 |
- Chemical Finish Black Oxide for Copper, Mil-F-495
- AWG Copper Wire Size Table and Data Chart @ 100 Degrees F
- Copper Tube Joints Working Pressure Solder or Brazing Joints Based on ASME Standard B31.9
- Copper Under Coat Finishing Specification Mil-C-14550
- Copper UNS Number Alloys Table and Chart
- Coefficient of Friction Equation and Table Chart
- Copper Tubing Size Chart ASTM B-88
- Copper Tubing HVAC Size Chart
- Working Pressures Copper Tubing
