Related Resources: fluid flow
Copper Tubing HVAC Size Chart
Hydraulic, Pneumatic Design & Engineering
Fluid Power Engineering
Copper Tubing HVAC Size Chart- Size and Physical Characteristics of Copper Tube: ACR (Air-Conditioning and Refrigeration Field Service) (A= Annealed Temper, D=Drawn Temper)
Nominal or Standard Size, inches |
Nominal Dimensions, inches |
Calculated Values (based on nominal dimensions) | ||||
Outside Diameter |
Inside Diameter |
Wall Thickness |
Weight of Tube Only, pounds/linear ft |
Contents of Tube, cu ft /linear ft |
1/8 |
A |
.125 |
.065 |
.030 |
.0347 |
.00002 |
3/16 |
A |
.187 |
.128 |
.030 |
.0575 |
.00009 |
1/4 |
A |
.250 |
.190 |
.030 |
.0804 |
.00020 |
5/16 |
A |
.312 |
.248 |
.032 |
.109 |
.00034 |
3/8 |
A |
.375 |
.311 |
.032 |
.134 |
.00053 |
D |
.375 |
.315 |
.030 |
.126 |
.00054 |
1/2 |
A |
.500 |
.436 |
.032 |
.182 |
.00103 |
D |
.500 |
.430 |
.035 |
.198 |
.00101 |
5/8 |
A |
.625 |
.555 |
.035 |
.251 |
.00168 |
D |
.625 |
.545 |
.040 |
.285 |
.00162 |
3/4 |
A |
.750 |
.680 |
.035 |
.305 |
.00252 |
A |
.750 |
.666 |
.042 |
.362 |
.00242 |
D |
.750 |
.666 |
.042 |
.362 |
.00242 |
7/8 |
A |
.875 |
.785 |
.045 |
.455 |
.00336 |
D |
.875 |
.785 |
.045 |
.455 |
.00336 |
1 1/8 |
A |
1.125 |
1.025 |
.050 |
.655 |
.00573 |
D |
1.125 |
1.025 |
.050 |
.655 |
.00573 |
1 3/8 |
A |
1.375 |
1.265 |
.055 |
.884 |
.00875 |
D |
1.375 |
1.265 |
.055 |
.884 |
.00875 |
1 5/8 |
A |
1.625 |
1.505 |
.060 |
1.14 |
.0124 |
D |
1.625 |
1.505 |
.060 |
1.14 |
.0124 |
2 1/8 |
D |
2.125 |
1.985 |
.070 |
1.75 |
.0215 |
2 5/8 |
D |
2.625 |
2.465 |
.080 |
2.48 |
.0331 |
3 1/8 |
D |
3.125 |
2.945 |
.090 |
3.33 |
.0473 |
3 5/8 |
D |
3.625 |
3.425 |
.100 |
4.29 |
.0640 |
4 1/8 |
D |
4.125 |
3.905 |
.110 |
5.38 |
.0833 |
External Surface, sq ft per linear ft |
Internal Surface, sq ft/linear ft |
1/8 |
A |
.0327 |
.0170 |
3/16 |
A |
.0492 |
.0335 |
1/4 |
A |
.0655 |
.0497 |
5/16 |
A |
.0817 |
.0649 |
3/8 |
A |
.0982 |
.0814 |
D |
.0982 |
.0821 |
1/2 |
A |
.131 |
.114 |
D |
.131 |
.113 |
5/8 |
A |
.164 |
.145 |
D |
.164 |
.143 |
3/4 |
A |
.196 |
.178 |
A |
.196 |
.174 |
D |
.196 |
.174 |
7/8 |
A |
.229 |
.206 |
D |
.229 |
.206 |
1 1/8 |
A |
.294 |
.268 |
D |
.294 |
.268 |
1 3/8 |
A |
.360 |
.331 |
D |
.360 |
.331 |
1 5/8 |
A |
.425 |
.394 |
D |
.425 |
.394 |
2 1/8 |
D |
.556 |
.520 |
2 5/8 |
D |
.687 |
.645 |
3 1/8 |
D |
.818 |
.771 |
3 5/8 |
D |
.949 |
.897 |
4 1/8 |
D |
1.08 |
1.02 |
- Chemical Finish Black Oxide for Copper, Mil-F-495
- AWG Copper Wire Size Table and Data Chart @ 100 Degrees F
- Copper Tube Joints Working Pressure Solder or Brazing Joints Based on ASME Standard B31.9
- Copper Under Coat Finishing Specification Mil-C-14550
- Copper UNS Number Alloys Table and Chart
- Coefficient of Friction Equation and Table Chart
- Copper Tubing Size Chart ASTM B-88
- Copper Tubing HVAC Size Chart
- Working Pressures Copper Tubing
