Structural A36 Steel Wide Flange I Beam Section Properties Table
Structural Materials Menu
Engineering Materials Menu
ASTM Steel Wide Channel H Beam Section Properties various sizes ranging W4 - W12
ASTM A36 Wide Channel H Beam is one of the most widely used carbon steels in industry. A36 steel it is weldable, formable, and machinable. Galvanizing the steel increases its corrosion-resistance.
  • Weight per foot
  • Cross Section Area
  • Area Moment of Inertia
  • Wall Thickness
Related Resources:
The following chart table gives cross section engineering data for ASTM Structural Steel Wide Channel I Beam as follows:
 in × lb/ft Area (in2) d (in) bf (in) tf (in) tw (in) Ixx (in4) Iyy (in4)
W12x336 98.8 16.82 13.385 2.955 1.775 4060 1190
W12x305 89.6 16.32 13.235 2.705 1.625 3550 1050
W12x279 81.9 15.85 13.14 2.47 1.53 3110 937
W12x252 74.1 15.41 13.005 2.25 1.395 2720 828
W12x230 67.7 15.05 12.895 2.07 1.285 2420 742
W12x210 61.8 14.71 12.79 1.9 1.18 2140 664
W12x190 55.8 14.38 12.67 1.735 1.06 1890 589
W12x170 50 14.03 12.57 1.56 0.96 1650 517
W12x152 44.7 13.71 12.48 1.4 0.87 1430 454
W12x136 39.9 13.41 12.4 1.25 0.79 1240 398
W12x120 35.3 13.12 12.32 1.105 0.71 1070 345
W12x106 31.2 12.89 12.22 0.99 0.61 933 301
W12x96 28.2 12.71 12.16 0.9 0.55 833 270
W12x87 25.6 12.53 12.125 0.81 0.515 740 241
W12x79 23.2 12.38 12.08 0.735 0.47 662 216
W12x72 21.1 12.25 12.04 0.67 0.43 597 195
W12x65 19.1 12.12 12 0.605 0.39 533 174
W12x58 17 12.19 10.01 0.64 0.36 475 107
W12x53 15.6 12.06 9.995 0.575 0.345 425 95.8
W12x50 14.7 12.19 8.08 0.64 0.37 394 56.3
W12x45 13.2 12.06 8.045 0.575 0.335 350 50
W12x40 11.8 11.94 8.005 0.515 0.295 310 44.1
W12x35 10.3 12.5 6.56 0.52 0.3 285 24.5
W12x30 8.79 12.34 6.52 0.44 0.26 238 20.3
W12x26 7.65 12.22 6.49 0.38 0.23 204 17.3
W12x22 6.48 12.31 4.03 0.425 0.26 156 4.66
W12x19 5.57 12.16 4.005 0.35 0.235 130 3.76
W12x16 4.71 11.99 3.99 0.265 0.22 103 2.82
W12x14 4.16 11.91 3.97 0.225 0.2 88.6 2.36
W10x112 32.9 11.36 10.415 1.25 0.755 716 236
W10x100 29.4 11.1 10.34 1.12 0.68 623 207
W10x88 25.9 10.84 10.265 0.99 0.605 534 179
W10x77 22.6 10.6 10.19 0.87 0.53 455 154
W10x68 20 10.4 10.13 0.77 0.47 394 134
W10x60 17.6 10.22 10.08 0.68 0.42 341 116
W10x54 15.8 10.09 10.03 0.615 0.37 303 103
W10x49 14.4 9.98 10 0.56 0.34 272 93.4
W10x45 13.3 10.1 8.02 0.62 0.35 248 53.4
W10x39 11.5 9.92 7.985 0.53 0.315 209 45
W10x33 9.71 9.73 7.96 0.435 0.29 170 36.6
W10x30 8.84 10.47 5.81 0.51 0.3 170 16.7
W10x26 7.61 10.33 5.77 0.44 0.26 144 14.1
W10x22 6.49 10.17 5.75 0.36 0.24 118 11.4
W10x19 5.62 10.24 4.02 0.395 0.25 96.3 4.29
W10x17 4.99 10.11 4.01 0.33 0.24 81.9 3.56
W10x15 4.41 9.99 4 0.27 0.23 68.9 2.89
W10x12 3.54 9.87 3.96 0.21 0.19 53.8 2.18
W8x67 19.7 9 8.28 0.935 0.57 272 88.6
W8x58 17.1 8.75 8.22 0.81 0.51 228 75.1
W8x48 14.1 8.5 8.11 0.685 0.4 184 60.9
W8x40 11.7 8.25 8.07 0.56 0.36 146 49.1
W8x35 10.3 8.12 8.02 0.495 0.31 127 42.6
W8x31 9.13 8 7.995 0.435 0.285 110 37.1
W8x28 8.25 8.06 6.535 0.465 0.285 98 21.7
W8x24 7.08 7.93 6.495 0.4 0.245 82.8 18.3
W8x21 6.16 8.28 5.27 0.4 0.25 75.3 9.77
W8x18 5.26 8.14 5.25 0.33 0.23 61.9 7.97
W8x15 4.44 8.11 4.015 0.315 0.245 48 3.41
W8x13 3.84 7.99 4 0.255 0.23 39.6 2.73
W8x10 2.96 7.89 3.94 0.205 0.17 30.8 2.09
W6x20 5.87 6.2 6.02 0.365 0.26 41.4 13.3
W6x16 4.74 6.28 4.03 0.405 0.26 32.1 4.43
W6x15 4.43 5.99 5.99 0.26 0.23 29.1 9.32
W6x12 3.55 6.03 4 0.28 0.23 22.1 2.99
W6x9 2.68 5.9 3.94 0.215 0.17 16.4 2.19
W5x19 5.54 5.15 5.03 0.43 0.27 26.2 9.13
W5x16 4.68 5.01 5 0.36 0.24 21.3 7.51
W4x13 3.83 4.16 4.06 0.345 0.28 11.3 3.86
www.engineersedge.com
Advertising | Contact
