Wood Strength and Related Engineering Design Properties
Properties of Wood at 12% Moisture Content (Average Values from Tests on Clear Pieces 2 x 2 inches in Cross Section per ASTM D143)
Wood is a naturally formed organic material consisting essentially of elongated tubular elements called cells arranged in a parallel manner for the most part. These cells vary in dimensions and wall thickness with position in the tree, age, conditions of growth, and kind of tree. The walls of the cells are formed principally of chain molecules of cellulose, polymerized from glucose residues and oriented as a partly crystalline material. These chains are aggregated in the cell wall at a variable angle, roughly parallel to the axis of the cell. The cells are cemented by an amorphous material called lignin. The complex structure of the gross wood approximates a rhombic system. The direction parallel to the grain and the axis of the stem is longitudinal (L), the two axes across the grain are radial (R) and tangential (T) with respect to the cylinder of the tree stem. This anisotropy and the molecular orientation account for the major differences in physical and mechanical properties with respect to direction which are present in wood.
Standard nomenclature of lumber is based on commercial practice which groups woods of similar technical qualities but separate botanical identities under a single name. For listings of domestic hardwoods and softwoods see ASTM D1165 and the ‘‘Wood Handbook.’’
1 Impact bending height drop in inches for failure with 50-lb hammer
R = radial
T = tangential
Sources:
Tabulated from ‘‘Wood Handbook,’’ Tropical Woods no. 95, and unpublished data from the USDA Forest service, Forest Laboratory.
- Wood Structural Design Effective Length for Bending Members Formula and Calculator
- Engineering Properties for Wood #1
- Engineering Properties for Wood #2
- Engineering Properties for Wood #3
- Wood Column Stability Factor Formulas and Calculator
- Density of Wood as Function of Moisture Content Equation and Calculator
- Wood Maximum Dowel Bearing Strengths, for Dowel-Type Fasteseners Calculator
- Holding Power of Wood Screws The results of tests of the holding power of over 10,000 wood screws inserted in the side and end grain of seven kinds of wood.
- Honeycomb Beam & Panel Calculations Spreadsheet Calculator
- Lag Screws in Wood Pullout Withdraw Resistance Force Formulae and Calculator . Lag screws are commonly used because of their convenience, particularly where it would be difficult to fasten a bolt or where a nut on the surface would be objectionable.
- Lag Screw Wood Withdrawal Force Formula and Calculator per. AWC-NDS
- Plywood Minimum Bend Radius Design Practices . Plywood, after softening, may be bent on a cold ventilated form.
- Machinability of Wood
- Nail in Wood Pullout Withdraw Resistance Force Formulae and Calculator
- Wood Pressed Drift Pins / Bolts Pullout Withdraw Resistance Force Formulae and Calculator . A drift bolt (or drift pin) is a long pin of iron or steel, with or without head or point. It is driven into a bored hole through one timber and into an adjacent one, to prevent the separation of the timbers connected and to transmit lateral load.
- Structural Lumber Engineering Properties Structural Lumber Wood Engineering Properties. Modulus of Elasticity of Wood, Wood Engineering Design Data.
- Properties of Structural Wood - Specific Gravity and Weight of Wood
- Wood Screw Pullout Withdraw Resistance Force Formulae and Calculator
- Wood Glue Joint Bevel Surfaces Strength Formulae and Calculator Wood Adhesive tapered angle joint equations for stress in tension, stress in shear, tensile stress in brazed joint.
- Bolts and Screws Design Rules for Wood Installation, Allowable Loads and Stress in Wood with Fastener , Screw Spacing in Wood , Allowable Loads and Stress in Wood with Fastener - Wood Post-1991 Equations and Calculator
- Wood Butt (End to End) Joint Glue Adhesive Strength Equations and Calculator
- Wood Lap Joint Glue Adhesive Strength Design Equations and Calculator
- Wood Dowel Pin Shear Stress and Contact Pressure Check Equations and Calculator
- Wood Shear Stress Design Formulas and Calculator
- Engineering Properties of Lumber / Wood
- Equal Spacing Formulas and Calculator In the fabrication of wood or structural steel component spacing may be required and determined by the fabricator.
