Circular Tube Sections Cold-Formed Section Properties Calculator
Circular Hollow Tube Sections Cold-Formed per BS EN 10365 Euro Code 3 Section Properties Calculator
The following design data to Eurocode 3 (in accordance with the UK National Annex):
Section properties:
- Elliptical Hollow Tube Section Properties Calculator
- Rectangular Hollow Tube Section Properties Calculator
- Square Hollow Tube Hot-Finished Universal Sections Calculator
- Circular Hollow Tube Universal Section Properties Calculator
- Universal Tees (T) Split from UC Section Calculator
- Universal Tees Split From Universal Beams Calculator
- Universal Back to Back Unequal L Angles Section Properties Calculator
- Universal Back to Back Equal L Section Properties Calculator
- Universal Unequal leg Angles (L) Section Properties Calculator
- Universal Equal leg Angles L Section Properties Calculator
- Universal Parallel Flange Channels Properties Calculator
- Universal Bearing Piles Section Properties Calculator
- Universal Columns Section Properties Calculator
- Universal Narrow Beams Dimension Data
- Structural Steel AISC Shapes Properties Viewer
- AISC, ASTM Wide Flange #1 Steel
- AISC, ASTM Wide Flange #2 Steel
- AISC, ASTM S Narrow Flange I Beam Steel
- Steel Section Properties Chart Narrow I-Beam BS 4-1 | EN 1993-1-1
- Steel Section Properties Chart Wide I-Beam BS 4-1 | EN 1993-1-1
- Indian Standard Flange Beams per. IS 808
- Properties of Rolled-Steel Shapes I-Beam Sections, Standard GOST 8239-72
