Modulus of Elasticity, Young's Modulus For Common Engineering Materials Table
Engineering Metals and Materials Table of Contents
The following chart gives ultimate strength, yield point and modulus of elasticity data for steel and iron.
Ultimate Tensile
Strength
MPa
u)
Yield Strength
MPa
y)
ksi
GPa
210 - 456
1.45 - 3.15
40
A53 Seamless and Welded
Steel Pipe - Grade A
30,457
210
331
207
Steel Pipe - Grade B
30,457
210
414
241
A106 Seamless Carbon Steel Pipe
Grade A
30,457
210
400
248
Grade B
30,457
210
483
345
30,457
210
483
276
A252 Piling Steel Pipe
Grade 1
345
207
Grade 2
414
241
Grade 3
455
310
A501 Hot Formed Carbon Steel
Structural Tubing - Grade A
400
248
Structural Tubing - Grade B
483
345
A523 Cable Circuit Steel Piping
Grade A
331
207
Grade B
414
241
A618 Hot-Formed
High-Strength Low-Alloy
Structural Tubing - Grade Ia & Ib
483
345
A618 Hot-Formed
Structural Tubing - Grade II
414
345
A618 Hot-Formed
Structural Tubing - Grade III
448
345
API 5L Line Pipe
310 - 1145
175 - 1048
Acetals
403 - 1407
2.78 - 9.7
65
Acrylic
406
2.80
70
Aluminum Bronze
15,954
110
10,000
67
110
95
10,152.6
70
Antimony
2900
20
Aramid
8702 - 20,305
60 - 140
Beryllium (Be)
43,900
  303
Beryllium Copper
18999.9
131
1,740
12
Bone, spongy
1.45 - 435
0.01 - 3.0
Boron
65,266
450
3100
14,100
97
250
17,000
117
Bronze
10,500 - 20,000
72.4 - 138
Carbon Fibers
33,068
228
Cadmium
8,010
55.2
Carbon nanotube, single-walled
39,160 - 137,785
270 - 950
Cast Iron 4.5% C, ASTM A-48
170
Cellulose, cotton, wood pulp
80 - 240
Cellulose acetate, molded
12 - 58
Cellulose acetate, sheet
30 - 52
Cellulose nitrate, celluloid
50
Chlorinated polyether
39
Chlorinated PVC (CPVC)
Chromium
36,000
248
Cobalt
30,600
211
Concrete, High Strength
(compression)
40
(compression)
16,969
117
220
70
Diamond (C)
102,000 - 174,000
700 - 1,200
50
(compression)
Epoxy resins
26 - 85
Fiberboard, Medium Density
Flax fiber
Glass
17 - 29
0.12 - 0.2
50
(comp.)
Glass reinforced polyester matrix
10,732
  74
Granite
5,801
40
Graphene
1000
Grey Cast Iron
130
Hemp fiber
35
Inconel
29,700
205
Iridium
76,000
524
Iron
28,500
  200
Lead
2,030
14
Magnesium metal (Mg)
6,527
45
Manganese
23,100
159
Marble
7,832
~54
15
Medium-density fiberboard
580
4
Mercury
Molybdenum (Mo)
47,717
  329
Monel Metal
24,000
160
Nickel
30,022
  207
Nickel Silver
18,129
125
Nickel Steel
27,000
186
Niobium (Columbium)
14,938
103
290 - 580
2 - 4
45 - 90
45
Nylon-66
60 - 80
Oak Wood (along grain)
11
Osmium
1,435 - 1,638
  9.9 - 11.3
Phenolic cast resins
33 - 59
Phenol-formaldehyde
molding compounds
45 - 52
Phosphor Bronze
16,244
112
Pine Wood (along grain)
9
40
Platinum
24,800
171
Plutonium
14,000
 96.5
Polyacrylonitrile, fibers
200
Polybenzoxazole
362.6
2.5
Polycarbonates
377
2.6
52 - 62
Polyethylene HDPE (high density)
81 - 217.6
0.565 - 1.5
15
Polyethylene Terephthalate, PET
870 - 2030.5
6 - 14
55
Polyamide
420
2.95
85
Polyisoprene, hard rubber
39
Polymethylmethacrylate (PMMA)
348 - 493
2.4 - 3.4
Polyimide aromatics
449
3.1
68
Polypropylene, PP
217 - 290
1.5 - 2
28 - 36
Polystyrene, PS
435 - 507.6
3 - 3.5
30 - 100
Polyethylene, LDPE (low density)
0.11 - 65.2
0.11 - 0.45
Polytetrafluoroethylene (PTFE)
58
0.4
Polyurethane cast liquid
90.5 - 797.7
0.624 - 5.5
10 - 20
Polyurethane elastomer
29  - 55
Polyvinylchloride (PVC)
348 - 594
2.4 - 4.1
Potassium
Rhodium
52,100
359
Rubber, small strain
1.45 - 14.5
0.01 - 0.1
Sapphire
36,259
250
Selenium
Silicon
16,302
  112.4
Silicon Carbide
65,266.9
450
3440
Silver
11,022.8
76
Sodium
Steel, High Strength Alloy
ASTM A-514
29,000
200
755
670
Steel, stainless AISI 302
28,000
193
850
506
Steel, Structural ASTM-A36
29,000
200
403
245
Tantalum
27000
186
(PTFE)
56.9 - 326
0.392 - 2.25
Thorium
10,602
73.1
Tin
6,030
41.6
Titanium
16
120
Titanium Alloy
17,404
105 - 120
900
730
Tooth enamel
464 - 14,242
3.2 - 98.2
Tungsten (W)
58,000
400
Tungsten Carbide (WC)
65,266 - 94,274
450 - 650
Uranium, Cast
27,557
  190
Vanadium
18,200
125.5
Wrought Iron
14,242.4
98.2
Zinc
14,000
96.5
Material
Ultimate Strength Yield Point
X 1000/in2
(T) Tension
X 1000/in2
Compression,
in terms of T
Shear in terms of T
in Tension (E)
x 106 psi
in Shear,
in terms of E
Cast iron, grey, class 20 20a 3.6 T - 4.4 T 1.6 T ....... 11.6 0.40 E
class 25
25a
3.6 T - 4.4 T 1.4 T
14.2
0.40 E
class 30
30a
3.6 T - 4.4 T
1.4 T
14.5
0.40 E
class 35
35a
3.6 T - 4.4 T 1.4 T
16.0
0.40 E
class 40
40a
3.6 T - 4.4 T
1.3 T
17
0.40 E
class 50
50a
3.6 T - 4.4 T
1.3 T
18
0.40 E
class 60
60a
2.8 T
1.O T
19.9
0.40 E
Malleable
40 to 100
30 to 80
25
0.43 E
nodular (ductile iron)
60 to 120
40 to 90
23
Cast Steel, carbon
60 to 100
T
0.75 T
30 to 70
30
0.38 E
low alloy
70 to 200
T
0.75 T
45 to 170
30
0.38 E
Steel, SAE 950
66 to 70
T
0.75 T
45 to 50-
30
0.38 E
1025 (low carbon)
60 to 103
T
0.75 T
40 to 90
30
0.38 E
1045 (medium carbon)
80 to 182
T
0.75 T
50 to 162
30
0.38 E
1095 (high carbon)
90 to 213
T
0.75 T
20 to 150
30
0.38 E
1112 ( free cutting)
60 to 100
T
0.75 T
30 to 95
30
0.38 E
1212 ( free cutting)
57 to 80
T
0.75 T
25 to 72
30
0.38 E
1330 (alloy)
90 to 162
T
0.75 T
27 to 149
30
0.38 E
2517 (alloy)
88 to 190
T
0.75 T
60 to 155
30
0.38 E
3140 (alloy)
93 - 188
T
0.75 T
62 to 162
30
0.38 E
3310 (alloy)
104 to 172
T
0.75 T
56 to 142
30
0.38 E
4023 (alloy)
105 to 170
T
0.75 T
60 to 114
30
0.38 E
4130 (alloy)
81 to 179
T
0.75 T
46 to 161
30
0.38 E
4340 (alloy)
109 to 220
T
0.75 T
68 to 200
30
0.38 E
4640 (alloy)
98 to 192
T
0.75 T
62 to 169
30
0.38 E
4820 (alloy)
98 to 209
T
0.75 T
68 to 184
30
0.38 E
5150 (alloy)
98 to 210
T
0.75 T
51 to 190
30
0.38 E
52100 (alloy)
100 to 238
T
0.75 T
81 to 228 30
0.38 E
6150 (alloy)
96 to 228
T
0.75 T
59 to 210
30
0.38 E
8650 (alloy) 110 to 228 T 0.75 T 69 to 206 30 0.38 E
8740 (alloy) 100 to 179 T 0.75 T 60 to 165 30 0.38 E
9310 (alloy) 117 to 187 T 0.75 T 63 to 162 30 0.38 E
9840 (alloy) 120 to 285 T 0.75 T 45 to 50 30 0.38 E
Chrome Alloy 13 65 ksi
449 MPa
-   40 ksi
276 MPa
Steel Stainless, SAE
30302f 85 to 125 T ....... 35 to 95 28 0.45 E
30321f 85 to 95 T ....... 30 to 60 28 .......
30347f 90 to 100 T ....... 35 to 65 28 0.40 E
51420f 95 to 230 T ....... 50 to 195 29 .......
51430f 75 to 85 T ....... 40 to 70 29 .......
51446f 80 to 85 T ....... 50 to 70 29 .......
51501f 70 to 175 T ....... 30 to 135 29 .......
Structural Steel
Common 60 to 75 T 0.75 T 33 29 0.41 E
Rivet 52 to 62 T 0.75 T 28 29 .......
Rivet, high strength 68 to 82 T 0.75 T 38 29 .......
Wrought iron 34 to 54 T 0.75 T 23 to 32 28 .......
a - Minimum specified value of the American  Society of Testing Materials. References Cast irom, ASTM A48, structural steel fro bridges and structures, ASTM A7. Structural rivet steel , ASTM A141; high-strength structural rivet steel, ASTM A195
Conversions
  • 1 Pa (N/m2 ) = 1x10-6 N/mm2 = 1.4504x10-4 psi
  •  1 MPa = 10 6 N/m2 = 0.145x10 3 psi (lb f /in2 ) = 0.145 ksi
  • 1 GPa = 10 9 N/m2 = 10 6 N/cm2 = 10 3 N/mm2 = 0.145x10 6 psi (lb f /in2 )
  • 1 psi (lb/in2 ) = 0.001 ksi = 144 psf (lb f /ft2 ) = 6,894.8 Pa (N/m2 ) = 6.895x10 -3 N/mm2
