Trapezoidal Weirs Flow Formula and Calculator
Fluids Engineering and Design
Civil Engineering and Design
A trapezoidal weir is essentially a rectangular weir with a triangular weir on either side. (See Fig. 1) If the angle of the sides from the vertical is approximately 14° (i.e., 4 vertical and 1 horizontal), the weir is known as a Cipoletti weir. The discharge from the triangular ends of a Cipoletti weir approximately make up for the contractions that would reduce the flow over a rectangular weir. Therefore, no correction is theoretically necessary. This is not completely accurate, and for this reason, Cipoletti weirs are not used where great accuracy is required. The discharge is
Preview Premium Membership Calculator:" Flow Within Trapezoidal Weirs Calculator
Fig. 1 - Trapezoidal Weir
Eq. 1,
Q = 2/3 Cd b (2g)0.5 H1.5
The average value of the discharge coefficient is 0.63. The discharge from a Cipoletti weir is found by using Eq. 2.
Eq. 2,
Q = 1.86 b H1.5
H = height, m
b =
width of weir bottom, m
Q = Flow, m3/s
g = gravity, 9.81 m/s2
Cd = discharge coefficient (average = 0.63)
- Civil Engineering Reference Manual, Fifteeth Edition
- Triangular Weirs Flow Formula and Calculator
- Water Flow Over Rectangular Weir Formula and Calculator
- Weir Flow Rectangular Open Channel Water Flow Calculator and Formula
- Water Flow Kinetic Force in Flow Around Submerged Object Calculator and Equation.
- Partially Full Pipe Flow Calculator Determines the Flow within a partially full pipe using the Manning equation.
- Pipe Flow with Gradual Size Enlargement Formula and Calculator
- Barlow's Formula, Calculator and MAOP Design Factors Barlow's formula is used to verify that pipe used for gathering, transmission, and distribution lines can safely withstand operating pressures.
- Chézy and Manning's Equation Manning's equation, which is based on Chezy's equation, is method to calculate the free surface flow within a channel.
- Fluid Flow Open Channel Calculator Chezy and Manning's equation to determine the wetted perimeter, hydraulic radius, flow area, Chezy coefficient and flow velocity
- Hazen-Williams Method for Pipe Friction and Pressure Drop Hazen-Williams formula:
- Draining Time for Horizontal Tank Formulas and Calculator
- Draining Time for Vertical Tank Formulas and Calculator
- Draining Time for Spherical (Sphere) Tank Formulas and Calculator
- Hooghoudt's Drainage Rate Equation and Calculator
- Rainfall Runoff Rate Formulas and Calculator
- Design Rainfall Intensity and Peak Storm Water Runoff Rate Equations and Calculator
- Storm Drain Pipe Size Requirement Formula and Calculator
