Kinetic Force Around Submerged Object Calculator and Equation.
Water Flow Kinetic Force in Flow Around Submerged Object Calculator and Equation.
Fk = π · 0.5 · R · L · ρ · v2 · f
R = Radius of Sphere (ft)
r = Density of Fluid (lb/ft3)
v = Velocity of Fluid (ft/s)
f = Friction Factor (dimensionless)
Fk = Fluid Kinetic Force (lbf)
Reference: Bird, R.B., Stewart, W.E. and Lightfoot, E.N. (2002). Transport Phenomena (Second Ed.). John Wiley & Sons, Chapter: 3, Page: 110.
- Fluid Kinetic Force Calculator and Equation
- Fluid Pressure Loss Along Pipe Length of Uniform Diameter Pressure drop in pipes, Friction, Vertical pipe difference or elevation, Changes of kinetic energy, Calculation of pressure drop
- Fluids Flow, Aerodynamics Calculate, Mach Number, Reynolds Number, Dynamics Pressure, Viscosity, Laminar CF Turbulent CF, Density
- Friction Losses to Water Flow in Copper Pipes Size 0.5 to 1.00 inch diameter
- Friction Flow Losses in Copper Tubing of Water in Sizes 1.25 to 1.5 inch diameter
- Friction Flow Losses in Copper Tubing of Water in Sizes 2 to 3 inch diameter
- Hazen-Williams Water Pressure Drop Flow Rates Calculator Equation Hazen–Williams equation is an empirical relationship which relates the flow of water in a pipe with the physical properties of the pipe
- Hydraulic Head Pressure Hydraulic head pressure or piezometric head is a specific measurement of liquid pressure above a geodetic datum.
- Nozzle, Venturi and Orifice Flowmeter Formula and Calculator Flow in a pipeline can be measured by a venturi meter, flow nozzle, or orifice plate
- Pipe Max Flow Rate Maximum recommended flow rates at the given pressure for ANSI schedule 40 pipe.
- Velocity and Flow Capacity of Oil Standard Tubes Velocity and Flow Capacity of Oil Standard Tubes Table
- Velocity and Flow Capacity of Oil Schedule 40 Pipe Velocity and Flow Capacity of Oil Schedule 40 Pipe
- Hydraulic Ram Pump for Pumping Water , Operation and Design Premium Membership Required
- Pelton Impulse Water Turbine Design Formulas This is a water turbine in which the pressure energy of the water is converted wholly to kinetic energy in one or more jets which impinge on buckets disposed around the periphery of a wheel.
