Proportional Weirs Equations and Calculator
Civil Engineering and Design
Fluids Engineering and Design
The proportional weir (Sutro weir) is used in water level control because it demonstrates a linear relationship between Q and H. Figure 1 illustrates a proportional weir whose sides are hyperbolic in shape.
Preview: Proportional Weirs Calculator
Figure 1 Proportional Weirs
aEq.1
Q = Cd · K · (π / 2) · ( 2 · g )0.5 · h
aEq. 2
K = 2 · x · y0.5
- x = on half base width in ft (m for S.I. units)
- y = height at some elevation in ft (m for S.I. units)
- Cd = discharge coefficient, average value .63
- h = base height in ft (m for S.I. units)
- K = height or curved portion of weir in ft (m for S.I. units)
- Q = design flow over the weir in cfs (m3/s for S.I. units)
- g = acceleration of gravity = 32.17 ft/s/s (9.81 m/s/s for S.I. units)
Equations Sutro Weir Design Formulas
bEq. 3
Hb = 1.5 Hc * ( Qmin / Qmax ) / ( 1 - Qmin /Qmax)
bEq. 4
Wb = Qmin / [ (2/3) 4.96 Hb1.5 ]
bEq. 5
x = ( Wb / 2 ) [ 1 - (0.315 tan-1 ( Z / Hb0.5) ) ]
X and Z are position parameters as shown in the diagram above. They will have the same units as Wb .
- Wb = base width in ft (m for S.I. units)
- Hb = base height in ft (m for S.I. units)
- Hc = max height or curved portion of weir in ft (m for S.I. units)
- Qmax = design maximum flow over the weir in cfs (m3/s for S.I. units)
- Qmin = design minimum flow over the weir in cfs (m3/s for S.I. units)
Reference
aCivil Engineering Reference Manual, Fifteenth Edition, Michael R. Lindeburg, PE
b U.S. DOT, Fed Highway Admin, Urban Design Manual, Circular No. 22, 2nd Ed. 2001 (Publ. No. FHWA-NHI-010021-HEC-22)
bBengtson, Harlan H. , “ Proportional Weir Design Equations ,” an online blog article
- Weir Flow Rectangular Open Channel Water Flow Calculator and Formula
- Trapezoidal Weirs Flow Formula and Calculator
- Triangular Weirs Flow Formula and Calculator
- Water Flow Kinetic Force in Flow Around Submerged Object Calculator and Equation.
- Dam's Spillway (overflow spillway) Flow Formula and Calculator
- Flow Through a Sluice Gate Formula and Calculator
- Flow over Channel Rise Hump Formula
- Pipe Flow with Gradual Size Enlargement Formula and Calculator
- Fluid Characteristics Chart Table | Fluids Data, Fluids Density | Vapor Pressure | Kinematic Viscosity
- Fluid Characteristics Chart Table #2 | Fluids Data, Fluids Density
