API Pipe Casing Data Tables Size 9.625 - 10.750
Fluid Flow Table of Contents
API Casing Data Tables Size 9.625 - 10.750.
Specification 5C3 of the American Petroleum Institute standardizes 14 casing sizes from 4.5 inches (11.43 cm) to 20 inches (50.80 cm) outside diameter ("OD"). This and related API documents also promulgate standards for the threaded end finish, the wall thickness (several are available in each size to satisfy various design parameters, and in fact are indirectly specified by standardized nominal weights per linear foot; thicker pipe obviously being heavier), and the strength and certain chemical characteristics of the steel material. Several material strengths: termed "Grades" and ranging from 40,000 pounds per square inch (276 MPa) to 150,000 pounds per square inch (1,034 MPa) minimum yield strength—are available for most combinations of OD and wall thickness to meet various design needs.
O.D. (inch)
Nominal
Weight T & C |
Grade
Collapse Pressure
(psi) |
Internal Yield Pressure
Minimum Yield (psi) |
Joint Strength
1000 lbs |
PE |
STC |
LTC |
BTC |
STC |
LTC |
BTC |
9.625
47.00
H2S-90
7100
7720
7720
7720
1027
1234
9.625
47.00
S-95
7100
8150
8150
8150
1053
1311
9.625
47.00
T-95
5090
8150
8150
8150
1040
1273
9.625
47.00
H2S-95
7100
8150
8150
8150
1040
1273
9.625
47.00
C-95
5090
8150
8150
8150
1040
1273
9.625
47.00
HCP-110
7100
9440
9440
9440
1213
1500
9.625
47.00
P-110
5300
9440
9440
9440
1213
1500
9.625
47.00
HCQ-125
7100
10730
10730
10730
1361
1650
9.625
47.00
Q-125
5640
10730
10730
10730
1361
1650
9.625
47.00
LS-140
7100
12010
12010
12010
1521
1839
9.625
53.50
L-80
6620
7930
7930
7930
1047
1286
9.625
53.50
HCL-80
8850
7930
7930
7930
1205
1414
9.625
53.50
N-80
6620
7930
7930
7930
1062
1329
9.625
53.50
HCN-80
8850
7930
7930
7930
1205
1414
9.625
53.50
C-90
7120
8920
8920
8920
1157
1386
9.625
53.50
H2S-90
8850
8920
8920
8920
1205
1414
9.625
53.50
S-95
8850
9410
9410
9410
1235
1502
9.625
53.50
T-95
7340
9410
9410
9410
1220
1458
9.625
53.50
H2S-95
8850
9410
9410
9410
1220
1458
9.625
53.50
C-95
7340
9410
9410
9410
1220
1458
9.625
53.50
HCP-110
8850
10900
10900
10900
1422
1718
9.625
53.50
P-110
7950
10900
10900
10900
1422
1718
9.625
53.50
HCQ-125
8850
12390
12390
12390
1595
1890
9.625
53.50
Q-125
8440
12390
12390
12390
1595
1890
9.625
53.50
LS-140
8850
13870
13870
13870
1783
2107
9.625
53.50
V-150
8960
14860
14860
14860
1909
2251
9.625
58.40
L-80
7890
8650
8650
8650
1151
1396
9.625
58.40
N-80
7890
8650
8650
8650
1167
1443
9.625
58.40
C-90
8560
9740
9740
9740
1272
1504
9.625
58.40
T-95
8880
10280
10280
10280
1341
1583
9.625
58.40
C-95
8880
10280
10280
10280
1341
1583
9.625
58.40
P-110
9760
11900
11900
11900
1564
1865
9.625
58.40
Q-125
10530
13520
13520
13520
1754
2052
9.625
59.40
C-90
8980
9970
9.625
59.40
T-95
9320
10520
9.625
64.90
C-90
10800
11000
9.625
64.90
T-95
11260
11610
9.625
70.30
C-90
12610
12010
9.625
70.30
T-95
13180
12680
9.625
75.60
C-90
13670
13040
9.625
75.60
T-95
14430
13770
9.750
59.20
H2S-90
9750
9610
9610
9610
1175
1383
9.750
59.20
S-95
9750
10150
10150
10150
1204
1469
9.750
59.20
H2S-95
9750
10150
10150
10150
1189
1426
9.750
59.20
HCP-110
9750
11750
11750
11750
1387
1681
9.750
59.20
P-110
9490
11750
11750
11750
1387
1681
9.750
59.20
Q-125
10210
13350
13350
13350
1555
1850
9.750
59.20
LS-140
10820
14950
14950
14950
1739
2061
9.875
62.80
H2S-90
10180
9970
9970
9940
1096
1304
9.875
62.80
S-95
10180
10520
10520
10490
1123
1385
9.875
62.80
H2S-95
10180
10520
10520
10490
1109
1344
9.875
62.80
P-110
10280
12180
12180
12140
1294
1584
9.875
62.80
Q-125
11140
13840
13840
13800
1451
1743
9.875
62.80
LS-140
11870
15510
15510
15460
1622
1942
10.750
32.75
H-40
840
1820
1820
205
10.750
40.50
H-40
1390
2280
2280
314
10.750
40.50
J-55
1580
3130
3130
3130
420
700
10.750
40.50
K-55
1580
3130
3130
3130
450
819
10.750
40.50
HCK-55
2100
3130
3130
3130
562
911
10.750
40.50
LS-65
1680
3700
3700
3700
491
806
10.750
40.50
N-80
1730
4560
4560
4560
597
964
10.750
40.50
HCN-80
2100
4560
4560
4560
681
1034
10.750
45.50
J-55
2090
3580
3580
3580
493
796
O.D. (inch)
Nominal
Weight T & C |
Grade
Body Yield
1000 lbs |
Wall (inch)
I.D.
(inch) |
Drift Diameter
(inch) |
API |
LSS |
9.625
47.00
H2S-90
1221
0.472
8.681
8.525
8.625
9.625
47.00
S-95
1289
0.472
8.681
8.525
8.625
9.625
47.00
T-95
1289
0.472
8.681
8.525
9.625
47.00
H2S-95
1289
0.472
8.681
8.525
8.625
9.625
47.00
C-95
1289
0.472
8.681
8.525
8.625
9.625
47.00
HCP-110
1493
0.472
8.681
8.525
8.625
9.625
47.00
P-110
1493
0.472
8.681
8.525
8.625
9.625
47.00
HCQ-125
1697
0.472
8.681
8.525
8.625
9.625
47.00
Q-125
1697
0.472
8.681
8.525
8.625
9.625
47.00
LS-140
1900
0.472
8.681
8.525
8.625
9.625
53.50
L-80
1244
0.545
8.535
8.379
8.500
9.625
53.50
HCL-80
1244
0.545
8.535
8.379
8.500
9.625
53.50
N-80
1244
0.545
8.535
8.379
8.500
9.625
53.50
HCN-80
1244
0.545
8.535
8.379
8.500
9.625
53.50
C-90
1399
0.545
8.535
8.379
8.500
9.625
53.50
H2S-90
1399
0.545
8.535
8.379
8.500
9.625
53.50
S-95
1477
0.545
8.535
8.379
8.500
9.625
53.50
T-95
1477
0.545
8.535
8.379
8.500
9.625
53.50
H2S-95
1477
0.545
8.535
8.379
8.500
9.625
53.50
C-95
1477
0.545
8.535
8.379
8.500
9.625
53.50
HCP-110
1710
0.545
8.535
8.379
8.500
9.625
53.50
P-110
1710
0.545
8.535
8.379
8.500
9.625
53.50
HCQ-125
1943
0.545
8.535
8.379
8.500
9.625
53.50
Q-125
1943
0.545
8.535
8.379
8.500
9.625
53.50
LS-140
2177
0.545
8.535
8.379
8.500
9.625
53.50
V-150
2332
0.545
8.535
8.379
8.500
9.625
58.40
L-80
1350
0.595
8.435
8.279
8.375
9.625
58.40
N-80
1350
0.595
8.435
8.279
8.375
9.625
58.40
C-90
1519
0.595
8.435
8.279
8.375
9.625
58.40
T-95
1604
0.595
8.435
8.279
8.375
9.625
58.40
C-95
1604
0.595
8.435
8.279
8.375
9.625
58.40
P-110
1857
0.595
8.435
8.279
8.375
9.625
58.40
Q-125
2110
0.595
8.435
8.279
8.375
9.625
59.40
C-90
1553
0.609
8.407
8.251
9.625
59.40
T-95
1634
0.609
8.407
8.251
9.625
64.90
C-90
1701
0.672
8.281
8.125
9.625
64.90
T-95
1796
0.672
8.281
8.125
9.625
70.30
C-90
1845
0.734
8.157
8.001
9.625
70.30
T-95
1948
0.734
8.157
8.001
9.625
75.60
C-90
1989
0.797
8.031
7.875
9.625
75.60
T-95
2100
0.797
8.031
7.875
9.750
59.20
H2S-90
1540
0.595
8.560
8.500
9.750
59.20
S-95
1626
0.595
8.560
8.500
9.750
59.20
H2S-95
1626
0.595
8.560
8.500
9.750
59.20
HCP-110
1882
0.595
8.560
8.500
9.750
59.20
P-110
1882
0.595
8.560
8.500
9.750
59.20
Q-125
2139
0.595
8.560
8.500
9.750
59.20
LS-140
2396
0.595
8.560
8.500
9.875
62.80
H2S-90
1635
0.625
8.625
8.500
9.875
62.80
S-95
1725
0.625
8.625
8.500
9.875
62.80
H2S-95
1725
0.625
8.625
8.500
9.875
62.80
P-110
1998
0.625
8.625
8.500
9.875
62.80
Q-125
2270
0.625
8.625
8.500
9.875
62.80
LS-140
2543
0.625
8.625
8.500
10.750
32.75
H-40
367
0.279
10.192
10.036
10.750
40.50
H-40
457
0.350
10.050
9.894
10.750
40.50
J-55
629
0.350
10.050
9.894
10.750
40.50
K-55
629
0.350
10.050
9.894
10.750
40.50
HCK-55
629
0.350
10.050
9.894
10.750
40.50
LS-65
743
0.350
10.050
9.894
10.750
40.50
N-80
915
0.350
10.050
9.894
10.750
40.50
HCN-80
915
0.350
10.050
9.894
10.750
45.50
J-55
715
0.400
9.950
9.794
9.875
Related Resources:
