API Pipe Casing Data Tables Size 10.750 - 11.750
Fluid Flow Table of Contents
API Casing Data Tables Size 10.750 - 11.750.
Specification 5C3 of the American Petroleum Institute standardizes 14 casing sizes from 4.5 inches (11.43 cm) to 20 inches (50.80 cm) outside diameter ("OD"). This and related API documents also promulgate standards for the threaded end finish, the wall thickness (several are available in each size to satisfy various design parameters, and in fact are indirectly specified by standardized nominal weights per linear foot; thicker pipe obviously being heavier), and the strength and certain chemical characteristics of the steel material. Several material strengths: termed "Grades" and ranging from 40,000 pounds per square inch (276 MPa) to 150,000 pounds per square inch (1,034 MPa) minimum yield strength—are available for most combinations of OD and wall thickness to meet various design needs.
O.D. (inch) |
Nominal |
Grade |
Collapse Pressure (psi) |
Internal Yield Pressure Minimum Yield (psi) |
Joint Strength 1000 lbs |
PE |
STC |
LTC |
BTC |
STC |
LTC |
BTC |
10.750 |
65.70 |
C-95 |
6960 |
9200 |
9200 |
9200 |
1263 |
1765 |
10.750 |
65.70 |
HCP-110 |
8640 |
10650 |
10650 |
10650 |
1472 |
2077 |
10.750 |
65.70 |
P-110 |
7500 |
10650 |
10650 |
10650 |
1472 |
2077 |
10.750 |
65.70 |
HCQ-125 |
8640 |
12110 |
12110 |
12110 |
1653 |
2291 |
10.750 |
65.70 |
Q-125 |
7920 |
12110 |
12110 |
12110 |
1653 |
2291 |
10.750 |
65.70 |
LS-140 |
8640 |
13560 |
13560 |
13560 |
1848 |
2554 |
10.750 |
65.70 |
V-150 |
8320 |
14530 |
14530 |
14530 |
1978 |
2730 |
10.750 |
71.10 |
H2S-90 |
9300 |
9520 |
9200 |
8980 |
1317 |
1822 |
10.750 |
71.10 |
S-95 |
9600 |
10050 |
9710 |
9480 |
1403 |
1971 |
10.750 |
71.10 |
H2S-95 |
9600 |
10050 |
9710 |
9480 |
1388 |
1918 |
10.750 |
71.10 |
HCP-110 |
9600 |
11640 |
11240 |
10980 |
1618 |
2257 |
10.750 |
71.10 |
P-110 |
9300 |
11640 |
11240 |
10980 |
1618 |
2257 |
10.750 |
71.10 |
Q-125 |
9990 |
13230 |
12780 |
12480 |
1817 |
2489 |
10.750 |
71.10 |
LS-140 |
10570 |
14810 |
14310 |
13980 |
2031 |
2775 |
10.750 |
71.10 |
V-150 |
10880 |
15870 |
15330 |
14970 |
2174 |
2966 |
10.750 |
73.20 |
C-90 |
8760 |
9850 |
10.750 |
73.20 |
T-95 |
9090 |
10390 |
10.750 |
79.20 |
C-90 |
10370 |
10750 |
10.750 |
79.20 |
T-95 |
10800 |
11350 |
10.750 |
85.30 |
C-90 |
12010 |
11680 |
10.750 |
85.30 |
T-95 |
12540 |
12330 |
11.750 |
42.00 |
H-40 |
1040 |
1980 |
1980 |
1980 |
307 |
554 |
11.750 |
47.00 |
J-55 |
1510 |
3070 |
3070 |
3070 |
477 |
807 |
11.750 |
47.00 |
K-55 |
1510 |
3070 |
3070 |
3070 |
509 |
935 |
11.750 |
47.00 |
HCK-55 |
2000 |
3070 |
3070 |
3070 |
638 |
1054 |
11.750 |
47.00 |
LS-65 |
1590 |
3630 |
3630 |
3630 |
557 |
931 |
11.750 |
54.00 |
J-55 |
2070 |
3560 |
3560 |
3560 |
568 |
931 |
11.750 |
54.00 |
K-55 |
2070 |
3560 |
3560 |
3560 |
606 |
1079 |
11.750 |
54.00 |
HCK-55 |
3100 |
3560 |
3560 |
3560 |
760 |
1216 |
11.750 |
54.00 |
LS-65 |
2250 |
4210 |
4210 |
4210 |
665 |
1074 |
11.750 |
60.00 |
J-55 |
2660 |
4010 |
4010 |
4010 |
649 |
1042 |
11.750 |
60.00 |
K-55 |
2660 |
4010 |
4010 |
4010 |
693 |
1208 |
11.750 |
60.00 |
HCK-55 |
4360 |
4010 |
4010 |
4010 |
869 |
1361 |
11.750 |
60.00 |
LS-65 |
2840 |
4730 |
4730 |
4730 |
759 |
1201 |
11.750 |
60.00 |
L-80 |
3180 |
5830 |
5830 |
5830 |
913 |
1399 |
11.750 |
60.00 |
HCL-80 |
4410 |
5830 |
5830 |
5830 |
1055 |
1555 |
11.750 |
60.00 |
N-80 |
3180 |
5830 |
5830 |
5830 |
924 |
1440 |
11.750 |
60.00 |
HCN-80 |
4410 |
5830 |
5830 |
5830 |
1055 |
1555 |
11.750 |
60.00 |
C-90 |
3360 |
6550 |
6550 |
6550 |
1011 |
1517 |
11.750 |
60.00 |
H2S-90 |
4410 |
6550 |
6550 |
6550 |
1055 |
1555 |
11.750 |
60.00 |
S-95 |
4410 |
6920 |
6920 |
6920 |
1077 |
1638 |
11.750 |
60.00 |
T-95 |
3440 |
6920 |
6920 |
6920 |
1066 |
1596 |
11.750 |
60.00 |
H2S-95 |
4410 |
6920 |
6920 |
6920 |
1066 |
1596 |
11.750 |
60.00 |
C-95 |
3440 |
6920 |
6920 |
6920 |
1066 |
1596 |
11.750 |
60.00 |
HCP-110 |
4410 |
8010 |
8010 |
8010 |
1242 |
1877 |
11.750 |
60.00 |
P-110 |
3610 |
8010 |
8010 |
8010 |
1242 |
1877 |
11.750 |
60.00 |
HCQ-125 |
4410 |
9100 |
9100 |
9100 |
1396 |
2074 |
11.750 |
60.00 |
Q-125 |
3680 |
9100 |
9100 |
9100 |
1396 |
2074 |
11.750 |
65.00 |
LS-65 |
3580 |
5170 |
5170 |
5170 |
837 |
1307 |
11.750 |
65.00 |
L-80 |
3870 |
6360 |
6360 |
6360 |
1007 |
1521 |
11.750 |
65.00 |
HCL-80 |
5740 |
6360 |
6360 |
6360 |
1152 |
1691 |
11.750 |
65.00 |
N-80 |
3870 |
6360 |
6360 |
6360 |
1019 |
1566 |
11.750 |
65.00 |
HCN-80 |
5740 |
6360 |
6360 |
6360 |
1164 |
1691 |
11.750 |
65.00 |
H2S-90 |
5140 |
7160 |
7160 |
7160 |
1164 |
1691 |
11.750 |
65.00 |
S-95 |
5740 |
7560 |
7560 |
7560 |
1189 |
1781 |
11.750 |
65.00 |
H2S-95 |
5740 |
7560 |
7560 |
7560 |
1177 |
1736 |
11.750 |
65.00 |
HCP-110 |
5740 |
8750 |
8750 |
8750 |
1371 |
2041 |
11.750 |
65.00 |
P-110 |
4480 |
8750 |
8750 |
8750 |
1371 |
2041 |
11.750 |
65.00 |
HCQ-125 |
5740 |
9940 |
9940 |
9940 |
1540 |
2256 |
11.750 |
65.00 |
Q-125 |
4690 |
9940 |
9940 |
9940 |
1540 |
2256 |
11.750 |
65.00 |
LS-140 |
5740 |
11130 |
11130 |
11130 |
1722 |
2516 |
11.750 |
71.00 |
H2S-90 |
7280 |
7800 |
7800 |
7800 |
1226 |
1790 |
11.750 |
71.00 |
S-95 |
7280 |
8230 |
8230 |
8230 |
1306 |
1933 |
11.750 |
71.00 |
H2S-95 |
7280 |
8230 |
8230 |
8230 |
1293 |
1884 |
11.750 |
71.00 |
HCP-110 |
7280 |
9530 |
9530 |
9530 |
1506 |
2215 |
O.D. (inch) |
Nominal |
Grade |
Body Yield 1000 lbs |
Wall (inch) |
I.D. (inch) |
Drift Diameter (inch) |
API |
LSS |
10.750 |
65.70 |
C-95 |
6960 |
1803 |
0.595 |
9.560 |
9.404 |
9.504 |
10.750 |
65.70 |
HCP-110 |
8640 |
2088 |
0.595 |
9.560 |
9.404 |
9.504 |
10.750 |
65.70 |
P-110 |
7500 |
2088 |
0.595 |
9.560 |
9.404 |
9.504 |
10.750 |
65.70 |
HCQ-125 |
8640 |
2373 |
0.595 |
9.560 |
9.404 |
9.504 |
10.750 |
65.70 |
Q-125 |
7920 |
2373 |
0.595 |
9.560 |
9.404 |
9.504 |
10.750 |
65.70 |
LS-140 |
8640 |
2657 |
0.595 |
9.560 |
9.404 |
9.504 |
10.750 |
65.70 |
V-150 |
8320 |
2847 |
0.595 |
9.560 |
9.404 |
9.504 |
10.750 |
71.10 |
H2S-90 |
9300 |
1856 |
0.650 |
9.450 |
9.294 |
10.750 |
71.10 |
S-95 |
9600 |
1959 |
0.650 |
9.450 |
9.294 |
10.750 |
71.10 |
H2S-95 |
9600 |
1959 |
0.650 |
9.450 |
9.294 |
10.750 |
71.10 |
HCP-110 |
9600 |
2269 |
0.650 |
9.450 |
9.294 |
10.750 |
71.10 |
P-110 |
9300 |
2269 |
0.650 |
9.450 |
9.294 |
10.750 |
71.10 |
Q-125 |
9990 |
2578 |
0.650 |
9.450 |
9.294 |
10.750 |
71.10 |
LS-140 |
10570 |
2888 |
0.650 |
9.450 |
9.294 |
10.750 |
71.10 |
V-150 |
10880 |
3094 |
0.650 |
9.450 |
9.294 |
10.750 |
73.20 |
C-90 |
8760 |
1915 |
0.672 |
9.406 |
9.250 |
10.750 |
73.20 |
T-95 |
9090 |
2021 |
0.672 |
9.406 |
9.250 |
10.750 |
79.20 |
C-90 |
10370 |
2079 |
0.734 |
9.282 |
9.126 |
10.750 |
79.20 |
T-95 |
10800 |
2194 |
0.734 |
9.282 |
9.126 |
10.750 |
85.30 |
C-90 |
12010 |
2243 |
0.797 |
9.156 |
9.000 |
10.750 |
85.30 |
T-95 |
12540 |
2367 |
0.797 |
9.156 |
9.000 |
11.750 |
42.00 |
H-40 |
1040 |
478 |
0.333 |
11.084 |
10.928 |
11.750 |
47.00 |
J-55 |
1510 |
737 |
0.375 |
11.000 |
10.844 |
11.750 |
47.00 |
K-55 |
1510 |
737 |
0.375 |
11.000 |
10.844 |
11.750 |
47.00 |
HCK-55 |
2000 |
737 |
0.375 |
11.000 |
10.844 |
11.750 |
47.00 |
LS-65 |
1590 |
817 |
0.375 |
11.000 |
10.844 |
11.750 |
54.00 |
J-55 |
2070 |
850 |
0.435 |
10.880 |
10.724 |
11.750 |
54.00 |
K-55 |
2070 |
850 |
0.435 |
10.880 |
10.724 |
11.750 |
54.00 |
HCK-55 |
3100 |
850 |
0.435 |
10.880 |
10.724 |
11.750 |
54.00 |
LS-65 |
2250 |
1005 |
0.435 |
10.880 |
10.724 |
11.750 |
60.00 |
J-55 |
2660 |
952 |
0.489 |
10.772 |
10.616 |
11.750 |
60.00 |
K-55 |
2660 |
952 |
0.489 |
10.772 |
10.616 |
11.750 |
60.00 |
HCK-55 |
4360 |
952 |
0.489 |
10.772 |
10.616 |
11.750 |
60.00 |
LS-65 |
2840 |
1125 |
0.489 |
10.772 |
10.616 |
11.750 |
60.00 |
L-80 |
3180 |
1384 |
0.489 |
10.772 |
10.616 |
11.750 |
60.00 |
HCL-80 |
4410 |
1384 |
0.489 |
10.772 |
10.616 |
11.750 |
60.00 |
N-80 |
3180 |
1384 |
0.489 |
10.772 |
10.616 |
11.750 |
60.00 |
HCN-80 |
4410 |
1384 |
0.489 |
10.772 |
10.616 |
11.750 |
60.00 |
C-90 |
3360 |
1557 |
0.489 |
10.772 |
10.616 |
11.750 |
60.00 |
H2S-90 |
4410 |
1557 |
0.489 |
10.772 |
10.616 |
11.750 |
60.00 |
S-95 |
4410 |
1644 |
0.489 |
10.772 |
10.616 |
11.750 |
60.00 |
T-95 |
3440 |
1644 |
0.489 |
10.772 |
10.616 |
11.750 |
60.00 |
H2S-95 |
4410 |
1644 |
0.489 |
10.772 |
10.616 |
11.750 |
60.00 |
C-95 |
3440 |
1644 |
0.489 |
10.772 |
10.616 |
11.750 |
60.00 |
HCP-110 |
4410 |
1903 |
0.489 |
10.772 |
10.616 |
11.750 |
60.00 |
P-110 |
3610 |
1903 |
0.489 |
10.772 |
10.616 |
11.750 |
60.00 |
HCQ-125 |
4410 |
2163 |
0.489 |
10.772 |
10.616 |
11.750 |
60.00 |
Q-125 |
3680 |
2163 |
0.489 |
10.772 |
10.616 |
11.750 |
65.00 |
LS-65 |
3580 |
1223 |
0.534 |
10.682 |
10.526 |
11.750 |
65.00 |
L-80 |
3870 |
1505 |
0.534 |
10.682 |
10.526 |
11.750 |
65.00 |
HCL-80 |
5740 |
1505 |
0.534 |
10.682 |
10.526 |
11.750 |
65.00 |
N-80 |
3870 |
1505 |
0.534 |
10.682 |
10.526 |
11.750 |
65.00 |
HCN-80 |
5740 |
1505 |
0.534 |
10.682 |
10.526 |
11.750 |
65.00 |
H2S-90 |
5140 |
1639 |
0.534 |
10.682 |
10.526 |
11.750 |
65.00 |
S-95 |
5740 |
1788 |
0.534 |
10.682 |
10.526 |
11.750 |
65.00 |
H2S-95 |
5740 |
1788 |
0.534 |
10.682 |
10.526 |
11.750 |
65.00 |
HCP-110 |
5740 |
2070 |
0.534 |
10.682 |
10.526 |
11.750 |
65.00 |
P-110 |
4480 |
2070 |
0.534 |
10.682 |
10.526 |
11.750 |
65.00 |
HCQ-125 |
5740 |
2352 |
0.534 |
10.682 |
10.526 |
11.750 |
65.00 |
Q-125 |
4690 |
2352 |
0.534 |
10.682 |
10.526 |
11.750 |
65.00 |
LS-140 |
5740 |
2634 |
0.534 |
10.682 |
10.526 |
11.750 |
71.00 |
H2S-90 |
7280 |
1838 |
0.582 |
10.586 |
10.430 |
11.750 |
71.00 |
S-95 |
7280 |
1940 |
0.582 |
10.586 |
10.430 |
11.750 |
71.00 |
H2S-95 |
7280 |
1940 |
0.582 |
10.586 |
10.430 |
11.750 |
71.00 |
HCP-110 |
7280 |
2246 |
0.582 |
10.586 |
10.430 |
Related Resources:
- API Casing 4.500 - 5.000 Dia. Engineering Data Table
- API Casing 5.000 - 5.500 Dia. Engineering Data Table
- API Casing 5.500 - 6.625 Dia. Engineering Data Table
- API Casing 6.625 - 7.000 Dia. Engineering Data Table
- API Casing 7.000 - 7.625 Dia. Engineering Data Table
- API Casing 7.625 Dia. Engineering Data Table
- API Casing 7.625 - 8.625 Dia. Engineering Data Table
- API Casing 9.625 - 10.750 Dia. Engineering Data Table
- API Casing 10.750 Dia. Engineering Data Table
- API Casing 10.750 - 11.750 Dia. Engineering Data Table
- API Casing 11.750 - 13.375 Dia. Engineering Data Table
- API Casing 13.500 - 18.375 Dia. Engineering Data Table
