Extension Spring Rate Constant Calculator and Formula
Springs Resource Menu
This spring rate constant calculator will determine any of the values remaining by changing one of the variables then select the "calculate: button for the selected variable.
This calculator will calculate (estimate) the Spring Rate (k) of a extension spring. Spring rate is best determined by test and measurement techniques.
Equation: k = Gd4/8nD3
k = Spirng Constant, pounds of load per inch of deflection
G = modulus of rigidity of spring material, pounds per square inch
d = wire diameter, inches
n = number of active coils, which is the number of coils subjected to flexure (always less than the total number of coils)
D = mean coil diameter, inches = Outer Diameter - Wire Diameter
Open Extension Spring Rate "k" Constant Calculator
Extension Spring Design Suggestions
