Related Resources: fluid flow
Hazen-Williams Coefficients Table
Fluids Flow Engineering | Hydraulic & Pneumatic Design Engineering,
The Hazen–Williams equation has the advantage that the coefficient C is not a function of the Reynolds number , but it has the disadvantage that it is only valid for water . Also, it does not account for the temperature or viscosity of the water.
The following are Typical C factors used in the Hazen–Williams equation, which take into account some increase in roughness as pipe ages are as follows:
Material | Hazen-Williams (C) |
ABS - Acrylonite Butadiene Styrene | 130 |
Aluminum | 130 - 150 |
Asbestos Cement | 140 |
Asphalt Lining | 130 - 140 |
Brass | 130 - 140 |
Brick sewer | 100 |
Cast-Iron - new unlined | 130 |
Cast-Iron 10 years old | 107 - 113 |
Cast-Iron 20 years old | 89 - 100 |
Cast-Iron 30 years old | 75 - 90 |
Cast-Iron 40 years old | 64-83 |
Cast-Iron, asphalt coated | 100 |
Cast-Iron, cement lined | 140 |
Cast-Iron, bituminous lined | 140 |
Cast-Iron, sea-coated | 120 |
Cast-Iron, wrought plain | 100 |
Cement lining | 140 |
Concrete | 120 |
Concrete lined, steel forms | 140 |
Concrete lined, wooden forms | 120 |
Concrete, old | 100 - 110 |
Copper | 130 - 140 |
Corrugated Metal Pipe | 60 |
Ductile Iron Pipe (DIP) | 140 |
Ductile Iron, cement lined | 120 |
Fiber | 140 |
Fiber Glass Pipe - FRP | 150 |
Fire Hose (Rubber Lined) | 135 |
Galvanized iron | 120 |
Glass | 130 |
Lead | 130 - 140 |
Metal Pipes - Very to extremely smooth | 130 - 140 |
Plastic | 130 - 150 |
Polyethylene | 140 |
Polyvinyl chloride, PVC, CPVC | 140 |
Rusted Steel | 140 |
Steel Coal-Tar Enamel Lined | 145 - 150 |
Steel Forms | 140 |
Steel new unlined | 140 - 150 |
Steel, corrugated | 60 |
Steel, welded and seamless | 100 |
Steel, interior riveted | 90-110 |
Steel, interior riveted, no projecting rivets | 110 |
Steel, projecting girth and horizontal rivets | 100 |
Steel, vitrified, spiral-riveted | 90 - 110 |
Tin | 130 |
Vitrified Clay | 110 |
Wrought iron, plain | 100 |
Wood (well planed) | 130 |
Wooden or Masonry Pipe - Smooth | 120 |
Related Resources:
