Manning's Roughness Coefficient Chart Table
Fluid Flow Table of Contents
The Gauckley – Manning coefficient, often denoted as n , is an empirically derived coefficient, which is dependent on many factors, including surface roughness and sinuosity . When field inspection is not possible, the best method to determine n is to use photographs of river channels where n has been determined using Gauckler – Manning's formula.
Open Calculator to determine the open channel fluid flow:
Open channel fluid flow Calculator
Channel Material |
Constant n |
clean, uncoated cast iron |
0.013-0.015 |
clean, coated cast iron |
0.012-0.014 |
dirty, tuberculed cast iron |
0.015-0.035 |
riveted steel |
0.015-0.017 |
lock-bar and welded |
0.012-0.013 |
galvanized iron |
0.015-0.017 |
brass and glass |
0.009-0.013 |
Wood Stove Pipe | |
0.011-0.012 |
0.012-0.013 |
Concrete | |
0.016-0.017 |
0.015-0.016 |
0.012-0.014 |
0.011-0.012 |
vitrified sewer |
0.013-0.015 |
common-clay drainage tile |
0.012-0.014 |
asbestos |
0.011 |
planed timber |
0.011 |
canvas |
0.012 |
unplaned timber |
0.014 |
brick |
0.016 |
rubble masonry |
0.017 |
smooth earth |
0.018 |
firm gravel |
0.023 |
corrugated metal pipe |
0.022 |
natural channels, good condition |
0.025 |
natural channels with stones and weeds |
0.035 |
very poor natural channels |
0.060 |
