Enable Excel Macro Instructions
NOTE:
MS excel documents downloaded from the internet may include macros which will need to be enabled in your excel application.
The following is a method to enable macros in your excel application. Should this method not work, search the internet for alternative methods
Go to the file location of the Excel file.
Right-click and select Properties.
Select the Unblock checkbox at the bottom of the General tab in Properties, then select OK .
