Wind Force on Flag Pole Cylinder Formula and Calculator
Fluids Engineering and Design
Civil Engineering and Design
Wind Force on Flag Pole Cylinder Formula and Calculator (Airflow around a Cylinder Formula)
The characteristic drag coefficient plot for cylinders placed normal to the fluid flow is similar to the plot for spheres. The plot shown in Fig. 1 is for infinitely long cylinders, since there is additional wake drag at the cylinder ends. In calculating the Reynolds number, the cylinder diameter should be used as the characteristic dimension.
Preview Premium Membership Calculator Wind Force on Flag Pole Cylinder
Fig. 1 - Drag Coefficient for Cylinder
Density of air
Eq. 1,
ρ = p / ( R T
Kinematic Viscosity
Eq. 2,
v = µ /ρ
The characteristic dimension of a cylinder is its diameter.
The Reynolds number is
Eq. 3
Re = L v / ν = Dv / ν
Frontal area of the flagpole
Eq. 4
A = DL
Drag Force on the flagpole is
Eq. 5
FD = CD A ρ v2 / 2
FD = Drag Force on the flagpole, N
D = Pole or cylinder diamater, m
L = length of pole, m
µ = absolute viscosity (1.709 x 10-5 Pa · s)
CD = drag coefficient based on Reynolds number - see Fig. 1
ρ = density of air ~ 1.276 kg/m3 (temperature dependent)
v = Wind speed, m/s
ν = Kinematic viscosity, m2/s
p = pressure, kPa
R = Specific gas constant for Air 287.03 J / kg·K
T = Temperature, K
Re = Reynolds number,dimensionless
A = Frontal area of pole, m2
- Civil Engineering Reference Manual, Fifteeth Edition
- Density and Specific Weight of Air
- Reynolds Number Equation and Review
- Ideal Gas Assumptions Class 02
- Viscosity of Air, Dynamic and Kinematic
- Kinematic Viscosity Table Chart of Liquids
- Aerodynamic Drag Equation and Calculator
- Kinematic Viscosity Equation Application
- Air Flow Drag Coefficient Equations and Calculator
- Gas Discharge Rate Atmosphere From a Pressure Vessel
- Magnus Effect Calculator and Formula for Ball
- Ideal Gas Law - Thermodynamics
- Smoluchowski Effective Viscosity Equation and Calculator
- Wind Force Scales Beaufort Wind Scale, Saffir-Simpson Wind Scale, Fujita Wind Scale
- Wind Loading Main Force Resisting System Excel Calculator Spreadsheet
- Wind Pressure Exerted on Vertical Wall
- Circular Rod Forced Air Convection Equation and Calculator
- Wind Power Generation and Wind Power Turbine Design
- Wind Loading Analysis Design Wind Load Case 4 from Figure 6-9
- Wind Load Support Pole Calculator Spreadsheet
