Magnus Effect Calculator and Formula for Ball
Fluids Engineering and Design
Engineering Physics
The Magnus effect is the observed effect in which a spinning ball curves away from its principal flight path. In football, when a footballer strikes a ball off center, a spin force is applied. From the side the ball was struck, the motion of the ball is opposed by a drag force. Now, if we consider the opposite side of the ball, the result of the spin and drag force is the sum of their magnitude as both travel in the same direction. The asymmetry of force creates a pressure differential. This causes the ball to veer towards the region of low pressure; the side of the ball opposing the initial contact point.
Fig. 1. Forces on a spinning baseball in flight. The drag force FD acts in the -v direction, the Magnus force Fm acts in the ω x v direction, and the force of gravity FG acts downward.
When a spinning baseball travels through the atmosphere, it experiences the force of gravity in addition to the drag and Magnus forces, FD and FM, as shown in Fig. 1. Conventionally the magnitudes of these forces are parametrized as
Magnus force can be described with the following equation
FM = 1/2 · CL · ρ · A · v2
A = π · R2
Eq. 3
S = R ω / v
Declarations
A = cross sectional area of ball
FD = Magnus force (lift)
ρ = air density (1.23 kg / m3 )
v = velocity
ω = angular velocity of ball (rpm)
R = radius
S = slip factor
CD = drag coefficients
Figure 2, Experimental results for CL
Download: The effect of spin on the flight of a baseball ( Free membership minimum required )
- Polar Mass Moment of Inertia About Axis A-A and B-B of Common Shapes
- Mass Moment of Inertia Equations
- Estimated Motor and Transmission Inertia and Drive Requirements
- Gear Drive Motor Mass Moment of Inertia Equation
Credits:
Alan M. Nathan
Department of Physics
University of Illinois
