Oxygen Tank Evaporation Loss Formula and Calculator
Heat Transfer Engineering
Evaporation Loss from an Oxygen Tank Formula and Calculator
Liquefied gases are sometimes stored in well-insulated spherical or cylindrical containers vented to the atmosphere. The math expression for the steady-state heat transfer rate through the walls of such a container, with the radii of the inner and outer walls being r, and r, respectively and the temperatures at the inner and outer walls being T1 and To. The thermal conductivity of the insulation varies linearly with temperature from ko at To to k1, at T1 .
Qo = 4 · π · ro · r1 · ( ko + k1 ) / 2 · ( ( To - T1 ) / ( r1 - ro ) )
ro = Inner radius (m)
r1 = Outer radius (m)
To = Inner Layer Temperature (K)
T1 = Outer Layer Temperature (K)
ko = Thermal Conductivity of Outer Layer (W/m K)
k1 = Thermal Conductivity of Inner Layer (W/m K)
Qo = Flow Rate of Evaporation (g/s)
Bird, R.B., Stewart, W.E. and Lightfoot, E.N. (2002). Transport Phenomena (Second Ed.). John Wiley & Sons, Chapter: 10, Page: 327.
- Cylindrical Pressure Vessel Uniform Radial Load Equation and Calculator . Per. Roarks Formulas for Stress and Strain for membrane stresses and deformations in thin-walled pressure vessels.
- Cylindrical Pressure Vessel Uniform Internal or External Pressure, Ends Capped Equation and Calculator . Per. Roarks Formulas for Stress and Strain for membrane stresses and deformations in thin-walled pressure vessels.
- Cylindrical Pressure Vessel Uniform Axial Load Equation and Calculator . Per. Roarks Formulas for Stress and Strain
- Thick Walled Cylinder Stress Pressure Vessel Equations and Calculator
- Thin Walled Sphere Stress Pressure Vessel Equations and Calculator
- ASME Pressure Vessel Code Maximum Allowable Stress Values
- Pressure Vessel Required Shell Thickness Chart #1
- Pressure Vessel Required Shell Thickness Chart #2
- Pressure Vessel , Thin Wall Hoop Stress Equations
- Pressure Vessel , Thin Wall Hoop Stress Calculator
- Thermal Relief Load and Pressure Rise Macro Excel Spreadsheet Calculator
- Evaporation of Grease Review
- Properties of Dry Steam Table Chart
- Heat Loss or Gain From Pipe Excel Spreadsheet Calculator
- Net Refrigeration Capacity Equations and Calculator
- Overall Heat Transfer Coefficient Table Charts and Equation
- Thermal Conductivity, Heat Transfer
- Pressure Vessel Design Formula and Calculators Resources
