Measurement of Viscosity Vertical Falling Ball Equation and Calculator
Fluids Dynamics and Engineering
Viscosity of Fluid with Falling Sphere at Terminal Velocity Equation and Calculator
Measurement of Viscosity in a Vertical Falling Ball Viscometer Calculator
If a small sphere is allowed to fall from rest in a viscous fluid, it will accelerate until it reaches a constant velocity-the terminal velocity. When this steady-state condition has been reached the sum of all the forces acting on the sphere must be zero. The force of gravity on the solid acts in the direction of fall, and the buoyant and kinetic forces act in the opposite direction:
Preview: Viscosity of Fluid with Falling Sphere at Terminal Velocity Calculator
(4/3) · π · µ · r3 · ρs · g = 4/3 · π · R3 · ρ · g + 6 · π · µ ·R · vt
Here ρf, and ρs are the densities of the solid sphere and the fluid. Solving this equation for the terminal velocity gives
Eq. 2 (see Eq. 5)
µ = (2/9) · r2 · ( ρs - ρf ) · g / vt
Eq. 3
µ = ( g · d2 ) / ( 18 · l) · ( ρs - ρf ) · t
Eq. 4
µ = ( γs - γf ) · d2 / ( 18 · vt )
Eq. 5 (see Eq. 2)
Reynolds number
Re = d · v∞ · ρ / µ
This result may be used only if the Reynolds number is less than about 0.1.
This method provides an apparently simple method for determining viscosity. However, it is difficult to keep a homogeneous sphere from rotating during its descent, and if it does rotate, then Eq. 2 cannot be used. Sometimes weighted spheres are used in order to preclude rotation; then the left side of Eq. 1 has to be replaced by m, the mass of the sphere, times the gravitational acceleration.
Re = Reynolds Number (dimensionless)
vt = Terminal Velocity of sphere (m/s)
ρf = Density of Fluid (g/m3)
ρs = Density of Sphere (g/m3)
µ = Viscocity of Fluid (cP)
g = gravity (m/s2)
d = Diameter (m)
R = radius (m)
l = length of fall (m)
t = time sphere passing the length of l
γs = specific weight sphere
γf = specific weight fluid
t =
- Bird, R.B., Stewart, W.E. and Lightfoot, E.N. (2002). Transport Phenomena (Second ed.). John Wiley & Sons, Chapter: 2, Page: 61.
- Ping Yuan and Ben-Yuan Lin, American Laboratory October, 2008
- Kinematic Viscosity
- Density of Common Engineering Materials
- Air Density Table and Specific Weight Table, Equations and Calculator
- Density Equation and Review
- Mass Flow Rate Fluids Flow Equation
- Continuity Equation Fluids Flow
- Flow Meter Type Detectors Review
- Gas Flow Rate Through Orifice Equations and Calculator per. ISO 5167
- Harris Formula Pressure and Fluid Flow Equation and Calculator
- Siphon Flow Rate Equation and Calculator
- Laminar Flow Fluid Flow Review
- Film Thickness Lubrication Review
- Gear Lubricant Characteristics and Viscosity
