Hollow Cylinder Rotating Stress Equations and Calculator
Engineering Analysis
Strength and Mechanics of Materials Menu
Hollow Cylinder Rotating at ω rad/s Stress Equations and Calculator
Preview: Hollow Cylinder Rotating Stress Calculator
The stresses are
The tangential stress at any radius r formula
σθ = ρ ω2 / 8 * ( ( 3 - 2v ) / ( 1 - v ) ) [ ri2 + ro2 + ri2 ro2 / r2 - ( ( 1 + 2v ) / ( 3 - 2v ) ) r2 ]
The radial stress at any radius r formula
σr = ρ ω2 / 8 ( 3 - 2 v ) / ( 1 - v ) [ ri2 + ro2 - ri2 ro2 / r2 - r2 ]
The axial stress (ends free) at any radius r formula
Eq. 3
σz = ρ ω2 / 4 ( v / ( 1 - v ) (ri2 + ro2 - 2r2 )
The axial strain in the z direction (ends free) equation
Eq. 4
σz = v ρ ω2 / 4 ( 3 - 2v ) / ( 1 - v ) [ ri2 + ro2 - 2 r2 / ( 3 - 2 v) ]
The maximum stress occurs at the inner surface where r = ri formula
Eq. 5
σθ(max) = ρ ω2 / 4 ( 3 - 2v ) / ( 1 - v ) [ ro2 + ( ( 1 - 2v ) / ( 3 - 2 v) ri2 ] )
The axial strain in the z direction (ends free) formula
Eq. 6
εz = - v ρ ω2 / (2 E ) ( ri2 + ro2 )
The displacement u at any radius r of a thin hollow rotating disk formula
Eq. 7
u = [ ρ ω2 r / E ( ( 3 + v ) ( 1 - v )) / 8 ( ro2 + ri2 + ( 1 + v ) / ( 1 - v) ro2 ri2 / r2 - ( 1 + v ) / ( 3 + v ) r2 ) ]
Figure 1
where
E = modulus of elasticity or Young’s modulus, Pa [psi (lb/in2)]
r = radius to the stress element under consideration, m (in)
ro = outside radius, m (in)
ρ = mass density, kg/m3 (lbm/in3)
ω = angular velocity of the ring, rad/s
v = Poisson's ratio
- Rotating Solid Cylinder Stress Equations and Calculator
- Rotating Rings Bodies Stress Equations and Calculator
- Cylinder Stress and Deflection Rotation Equation and Calculator
- Critical Speeds of Rotating Shafts and Mass Review
- Counterbalancing Masses in Two or More Planes Formulas and Calculator
- Mass Moment of Inertia Equations
- Critical Speeds of Rotating Shafts with Single Loads Equations and Calculators
- Stresses in Rotating Disks (Annular Rings) of Constant Thickness Equation and Calculator
- Beam Deflection and Stress Calculators Formulas & Structural Analysis
Machine Design Handbook 2nd Edition, 2001
Prof. Dr. K. Lingaiah
Former Principal, Professor and Head, Department of Mechanical Engineering
University Visvesvaraya College of Engineering, Bangalore University, Bangalore
