Aircraft Hardware AN MS and NAS Part Quick Guide
ISO Metric Hardware
ANSI Hardware Guide
Military, Aerospace Hardware Selection Guide for AN, MS and NAS hardware. Each page includes pictoral references, part numebr and a short description.
PART NUMBER
DESCRIPTION
AN 42- AN 365
Eye Bolt, Hinge, Nut, Balls, Pulley, Wing Nut
AN 366 - AN 656
Nut Plate, Screw, Taper Pin, Clevis, Rod Ends
AN 658 - AN 117080
Terminal, Lug. Fittings, Bolt, Washer, Screw
AN 121501 - MS9168
Nut, Lock Pin, O-Ring, Snap Ring, Stud
MS 9169 - MS 16108
Bolt, Washer, Clamp, Nut, Bracket, Stud
MS 16187 - MS 16634
Stud, Lock Ring, Dowel Pin, Bolt, Nut
MS 16637 - MS 20253
Shoulder Screw, Terminal, Nut, Machine Key
MS 20257 - MS 21261
Hinge, Rivet, Nut, Turn Buckle, Lock Pin
MS 21262 - MS 24371
Socket Screw, Nut, Fittings, Misc..
MS 24388 - MS 24405
Fittings, Tapping Screw, Blind Rivet, Misc...
MS 27039 - MS 28778
Screw Pan Head, Hinge, Packing, Misc..
MS 28782 - MS 35691
Screw, Terminals, Wood Screws, Washers
MS 35743 - MS 172370
Rivets, Nut, Threaded Insert, Bolt, Screws
NAS 1 - NAS 330
Rivet, Rings, Bolts, Rod Assy., Bus Bar
NAS 333 - NAS 491
Screws, Bearing, plug, Washer, Clamp, Misc.
NAS 492 - 574
Misc.
NAS 577 - NAS 1044
Locking Nut, Rings, Shackle, Screws, Misc...
NAS 1045 - 1221
Cable Guide, Nut, Toggle Switch, misc..
NAS 1222 - 1401
Threaded Insert, Nut, Screws, Hose Clamp
NAS 1402 - 1406
Screw, Threaded Rod, U Bolt, Misc.
