Polar Area Moment of Inertia, Polar Section Modulus Properties of Common Shapes
Engineering Metals and Materials Table of Contents Polar Area Moment of Inertia and Section Modulus. The polar moment of inertia, J, of a cross-section with respect to a polar axis, that is, an axis at right angles to the plane of the cross-section, is defined as the moment of inertia of the cross-section with respect to the point of intersection of the axis and the plane. The polar moment of inertia may be found by taking the sum of the moments of inertia about two perpendicular axes lying in the plane of the cross-section and passing through this point. The polar section modulus (also called section modulus of torsion), Zp, for circular sections may be found by dividing the polar moment of inertia, J, by the distance c from the center of gravity to the most remote fiber. This method may be used to find the approximate value of the polar section modulus of sections that are nearly round. For other than circular cross-sections, however, the polar section modulus does not equal the polar moment of inertia divided by the distance c. Related: Polar Mass Moment of Inertia About Axis A-A, Axis B-B and Axis C-C. All calculators require a java enabled browser and a Premium Membership Account.
Link to this Webpage: © Copyright 2000 -
2024, by Engineers Edge, LLC |
