Tacks are short, sharp pointed nails often used with carpet, fabric and paper. When pushed by hand called a
thumb tack or
push pin .
- brass tack - brass tacks are commonly used where corrosion may be an issue, such as furniture where contact with human skin salts will cause corrosion on steel nails.
- canoe tack
- carpet tack
- Upholstery tacks - used to attach coverings to furniture
Casing nails - have a head that is smoothly tapered, in comparison to the "stepped" head of a finish nail . When used to install casing around windows or doors, they allow the wood to be pried off later with minimal damage when repairs are needed, and without the need to dent the face of the casing in order to grab and extract the nail. Once the casing has been removed, the nails can be extracted from the inner frame with any of the usual nail pullers .
clout-nail - a roofing nail
Coffin nail - general name for a nail used in a coffin, slang for a cigarette.
Coil nail - nails designed for use in a pneumatic nail gun assembled in coils.
Common nail - smooth shank, wire nail with a heavy, flat head. The typical nail for framing.
Convex head (nipple head, springhead) roofing nail - an umbrella shaped head with a rubber gasket for fastening metal roofing, usually with a ring shank.
Copper nail - nails made of copper for use with copper flashing or slate shingles etc.,
Corrugated fastener (wiggle nail) - a corrugated shaped piece of metal driven into miter joints in some furniture.
D-head (clipped head) nail - a common or box nail with part of the head removed such as when assembled into a "stick" for some pneumatic nail guns.
Double-headed (duplex, formwork, shutter, scaffold) nail - used for temporary nailing; nails can easily pulled for later disassembly
Dowel nail - a double headed nail without a "head" on the shank, a piece of round steel sharpened on both ends.
Drywall (plasterboard) nail - short, hardened, ring-shank nail with a very thin head.
Fiber cement nail - a nail for installing fiber cement siding .
Finish nail (bullet head nail, lost-head nail) - A wire nail with a small head intended to be minimally visible or driven below the wood surface and the hole filled to be invisible. has the same diameter as a box nail.
Gang nail - a nail plate
Hardboard pin - a small nail for fixing hardboard or thin plywood, often with a square shank
Horseshoe nail - nails used to hold horseshoes on hoofs
Joist hanger nail - special nails rated for use with joist hangers and similar brackets. Sometimes called "Teco nails" (1-1/2 x .148 shank nails used in metal connectors such as hurricane ties )
Lost-head nail - see finish nail.
Masonry (concrete) - lengthwise fluted, hardened nail for use in concrete
Oval wire nail - nails with an oval shank
Panel pin
Plastic strip
Gutter spike - Large long nail intended to hold wooden gutters in place.
Ring (annular, improved, jagged) shank nail - nails that have ridges circling the shank to provide extra resistance to pulling out (for example, the HurriQuake nail)
Roofing (clout) nail - generally a short nail with a broad head used with asphalt shingles , felt paper or the like.
Screw (helical) nail - a nail with a spiral shank.
Shake (shingle) nail - small headed nails to use for nailing shakes and shingles
Sprig - a small nail with either a headless, tapered shank or a square shank with a head on one side
Square nail - a cut nail
T-head nail - shaped like the letter T.
Veneer pin
Wire (French) nail - a general term for a nail with a round shank. These are sometimes called French nails from their country of invention.
Wire-weld collated nail - nails held together with slender wires for use in nail guns.
