Large and Small Diameter Lifting Pulley / Drums Equation and Calculator
A simple pulley and drum may be used to lift a weight by applying a force with a rope which is wrapped about he outer diameter of one of the diameters.
F : W = r : R |
W = (F x R)/r |
F x R = W x r |
R = (W x r)/F |
F = (F x R)/R |
r = (F x R)/W |
W = Unknown weight (lbs, N)
F = Applied force (lbs, N)
R = Radius large diameter (in, mm)
r = Radius small diameter (in, mm)
