Thermal Properties of Non-Metals
Engineering Metals and Materials
Thermal Conductivity, Heat Transfer Review
Conductivity: Heat transfer occurs at a lower rate across materials of low thermal conductivity than across materials of high thermal conductivity. Correspondingly, materials of high thermal conductivity are widely used in heat sink applications and materials of low thermal conductivity are used as thermal insulation . The thermal conductivity of a material may depend on temperature. The reciprocal of thermal conductivity is called thermal resistivity.
Density: The density, or more precisely, the volumetric mass density, of a substance is its mass per unit volume.
Specific Heat: Is the heat required to raise the temperature of the unit mass of a given substance by a given amount (usually one degree).
Material | Conductivity W/m-°C |
Density kg/m3 |
Specific Heat J/kg-°C |
ABS-Plastic | 0.25 |
1.014 x 103 |
1.26 x 103 |
Acetals | 0.3 |
1.42 x 103 |
1.5 x 103 |
Acrylic | 0.06 |
1.19 x 103 |
1.5 x 103 |
Alkyds | 0.85 |
2.0 x 103 |
1.3 x 103 |
Alumina, 96% | 21.0 |
3.8 x 103 |
880.0 |
Alumina, Pure | 37.0 |
3.9 x 103 |
880.0 |
Asbestos, Asbestos-sheets | 0.166 |
Asbestos, Cement | 2.08 |
Asbestos, Cement-boards | 0.74 |
Asbestos, Corregated, 4plies/in | 0.087 |
Asbestos, Felt, 20 lam/in | 0.078 |
Asbestos, Felt, 40 lam/in | 0.057 |
Asbestos, Loosely-packed | 0.154 |
520.0 |
Asphalt | 0.75 |
Bakelite | 0.19 |
Balsam wool 2.2lb/ft 3 | 0.04 |
35.0 |
Beryllia, 99.5% | 197.3 |
Brick, Building brick | 0.69 |
1.6 x 103 |
Brick, Carborundum brick | 18.5 |
Brick, Chrome brick | 2.32 |
3.0 x 103 |
Brick, Diatomaceous earth | 0.24 |
Brick, Face brick | 1.32 |
2.0 x 103 |
Brick, Fireclay | 1.04 |
2.0 x 103 |
Brick, Magnesite | 3.81 |
Carbon | 6.92 |
Cardboard, Celotex | 0.048 |
Cardboard, Corrugated | 0.064 |
Cement, Mortar | 1.16 |
Cement, Portland | 0.29 |
1.5 x 103 |
Concrete, Cinder | 0.76 |
Concrete, Stone 1-2-4 mix | 1.37 |
2.1 x 103 |
Cork, Corkboard,10lb/ft 3 | 0.043 |
160.0 |
Cork, Ground | 0.043 |
150.0 |
Cork, Regranulated | 0.045 |
80.0 |
Diamond, Film | 700.0 |
3.5 x 103 |
2.0 x 103 |
Diamond, Type IIA | 2.0 x 103 |
Diamond, Type IIB | 1.3 x 103 |
Diatomaceous earth | 0.061 |
320.0 |
E-Glass Fiber | 0.89 |
2.54 x 103 |
820.0 |
Epoxy, High Fill | 2.163 |
Epoxy, No Fill | 0.207 |
Felt, Hair | 0.036 |
265.0 |
Felt, Wool | 0.052 |
330.0 |
Fiber insulating board | 0.048 |
240.0 |
FR4 Epoxy Glass, 1oz Copper | 9.11 |
FR4 Epoxy Glass, 2 oz Copper | 17.71 |
FR4 Epoxy Glass, 4oz Copper | 35.15 |
FR4 Epoxy Glass, no Copper | 0.294 |
1.9 x 103 |
1.15 x 103 |
Glass, Borosilicate | 1.09 |
2.2 x 103 |
Glass, Pyrex | 1.02 |
2.23 x 103 |
837.0 |
Glass, Window | 0.78 |
2.7 x 103 |
Glass, Wool, 1.5lb/ft 3 | 0.038 |
24.0 |
Insulex, dry | 0.064 |
Kapok | 0.035 |
Kapton | 0.156 |
1.09 x 103 |
Magnesia, 85% | 0.067 |
270.0 |
Mica | 0.71 |
Mylar | 0.19 |
Nylon | 0.242 |
1.1 x 103 |
1.7 x 103 |
Phenolic, Paper based | 0.277 |
Phenolic, Plain | 0.519 |
Plaster, Gypsum | 0.48 |
1.44 x 103 |
Plaster, Metal lath | 0.47 |
Plaster, Wood lath | 0.28 |
Plexiglass | 0.19 |
Polycarbonate | 0.19 |
1.2 x 103 |
1.3 x 103 |
Polyethylene, High density | 0.5 |
950.0 |
2.3 x 103 |
Polyethylene, Low density | 0.35 |
920.0 |
2.3 x 103 |
Polyethylene, Medium density | 0.4 |
930.0 |
2.3 x 103 |
Polystyrene | 0.106 |
Polyvinyl chloride | 0.16 |
Pyrex | 1.26 |
Rock wool, 10lb/ft 3 | 0.04 |
160.0 |
Rock wool, Loosely packed | 0.067 |
64.0 |
Rubber, Butyl | 0.26 |
Rubber, Hard | 0.19 |
Rubber, Silicone | 0.19 |
Rubber, Soft | 0.14 |
Sawdust | 0.059 |
S-Glass Fiber | 0.9 |
2.49 x 103 |
835.0 |
Silica aerogel | 0.024 |
140.0 |
Silicon, 99.9% | 150.0 |
2.33 x 103 |
710.0 |
Silicone grease | 0.21 |
Stone, Granite | 2.8 |
2.64 x 103 |
Stone, Limestone | 1.3 |
2.5 x 103 |
Stone, Marble | 2.5 |
2.6 x 103 |
Stone, Sandstone | 1.83 |
2.2 x 103 |
Styrofoam | 0.035 |
Teflon | 0.22 |
1.04 x 103 |
Wood Shavings | 0.059 |
Wood, Cross Grain, Balsa, 8.8lb/ft 3 | 0.055 |
140.0 |
Wood, Cross Grain, Cypress | 0.097 |
460.0 |
Wood, Cross Grain, Fir | 0.11 |
420.0 |
Wood, Cross Grain, Maple | 0.166 |
540.0 |
Wood, Cross Grain, Oak | 0.166 |
540.0 |
Wood, Cross Grain, White pine | 0.112 |
430.0 |
Wood, Cross Grain, Yellow pine | 0.147 |
640.0 |
Aluminum-Oxide, Al 2 O 3 , 99.5% | 32.0 |
Aluminum-Oxide, Al 2 O 3 , 96% | 21.5 |
Aluminum-Oxide, Al 2 O 3 , 90% | 12.0 |
Thermal Conductivity Conversions:
1 cal/cm2/cm/sec/°C = 10.63 watts/in - °C
117 BTU/(hr-ft F) x (.293 watt-hr/BTU) x (1.8F/C) x (ft/12 in.) = 5.14 watts/in - °C
or
117 Btu / (hr-ft-F) x .04395 watt-hr-F-ft/(Btu=°C - in) = 5.14 watts/in-°C
