Fluid Volumetric Flow Rate Equation
Fluid Flow Table of Contents
The volumetric flow rate (V ) of a system is a measure of the volume of fluid passing a point in the system per unit time. The volumetric flow rate can be calculated as the product of the cross sectional area (A) for flow and the average flow velocity (v).
Equation (1)
V = A · v
If area is measured in square feet and velocity in feet per second, Equation 1 results in >volumetric flow rate measured in cubic feet per second. Other common units for volumetric flow >rate include gallons per minute, cubic centimeters per second, liters per minute, and gallons per hour.
Example:
A pipe with an inner diameter of 4 inches contains water that flows at an average velocity >of 14 feet per second. Calculate the volumetric flow rate of water in the pipe.
Solution:
Use Equation 1 and substitute for the area
V = ( π · r2 ) v
- Fluids Dynamic Simulator and stress reliever
- Fluid Stream From a Container Distance and Coordinates Equations and Calculator
- Flow over Channel Rise Hump Formula
- Fluid Flow Discharge Time under Falling Head Formula and Calculator
- Fluid Kinetic Force in Conduits Calculator and Equation
- Fluid Momentum Flux Equation and Calculator Momentum Flux is the rate of change of momentum flowing through unit area.
- Water Vapor Density atmosphere Equation - Water vapor in the atmosphere obeys the ideal gas law,
- Vapor Pressure Spreadsheet Calculator
- Viscosity of a Pure Liquid Estimation Equation and Calculator
- Viscosity Grade Table ISO 3448
- Viscous Torque and Power on Rotating Shafts Equations and Calculator
- Weymouth Pressure and Flow Formula and Calculator
