Related Resources: fluid flow
Square Section Flow Perp to Edge Surface Drag, Drag Coefficient Equation and Calculator
Long Square Section Flow Perpendicular to Edge Surface Drag, Drag Coefficient Equation and Calculator
Drag Equation:
Illustration
Description
L / d
Cd
Re / 104
Frontal Area
Long Square
Section |
1.00
> 0.1
2(0.5) L d
D = Drag (N);
ρ = fluid density (kg/m3);
L = Length (m);
d = Depth (m);
A = frontal area (m2);
V = fluid velocity (m/sec);
d = Diameter (m);
Density of air = 1.225 kg/m3
