Related Resources: fluid flow
Pressure Temperature Ratings for Pipe Flanges
(GPSA BOOK) Pressure- Temperature Ratings for Pipe Flanges and Flanged Fittings from ANSI B16.5-1981 |
CLASS
150
300
400
600
900
1500
2500
See Notes |
Material Group 1.1 (Carbon Steel) |
A105 (1)(3), A216-WCB(1), A515-70(1) A516-70 (1) A350-LF2, A537-C1.1 |
(a) (h) (a) (g) (d) |
⁰F
Pressures are in pounds per square inch, gauge (psig)
-20 to 100 200 300 400 |
285 260 230 200 |
740 675 655 635 |
990 900 875 845 |
1480 1350 1315 1270 |
2220 2025 1970 1900 |
3705 3375 3280 3170 |
6170 5625 5470 5280 |
500 600 650 700 |
170 140 125 110 |
600 550 535 535 |
800 730 715 710 |
1200 1095 1075 1065 |
1795 1640 1610 1600 |
2995 2735 2685 2665 |
4990 4560 4475 4440 |
750 800 850 900 |
95 80 65 50 |
505 410 270 170 |
670 550 355 230 |
1010 825 535 345 |
1510 1235 805 515 |
2520 2060 1340 860 |
4200 3430 2230 1430 |
950 1000 |
35 20 |
105 50 |
140 70 |
205 105 |
310 155 |
515 260 |
860 430 |
Material Group 2.1 (Type 304) |
A182-F304 (5), A182-F304H A240-304 (5)(6), A351-CF8 (5) A351-CF3 |
- - (f) |
-20 to
100 200 300 400 |
275 235 205 180 |
720 600 530 470 |
960 800 705 630 |
1440 1200 1055 940 |
2160 1800 1585 1410 |
3600 3000 2640 2350 |
6000 5000 4400 3920 |
500 600 700 |
170 140 110 |
435 415 405 |
585 555 540 |
875 830 805 |
1310 1245 1210 |
2185 2075 2015 |
3640 3460 3360 |
800 850 900 |
80 65 50 |
395 390 385 |
525 520 510 |
790 780 770 |
1180 1165 1150 |
1970 1945 1920 |
3280 3240 3200 |
950 1000 1050 1100 |
35 20 |
375 325 310 260 |
500 430 410 345 |
750 645 620 515 |
1125 965 925 770 |
1870 1610 1545 1285 |
3120 2685 2570 2145 |
1150 1200 1250 1300 |
195 155 110 85 |
260 205 145 110 |
390 310 220 165 |
585 465 330 245 |
980 770 550 410 |
1630 1285 915 685 |
1350 1400 1450 1500 |
60 50 35 25 |
85 65 45 30 |
125 90 70 50 |
185 145 105 70 |
310 240 170 120 |
515 400 285 200 |
Notes: (a) Permissible but not recommended for
prolonged use above 800⁰F
(d) Not to be used over 650⁰F (f) Not to be used over 800⁰F (g) Not to be used over 850⁰F (h) Not to be used over 1000⁰F Additional Notes: (1) Upon prolonged exposure to temperatures above about 800⁰F (425⁰C), the carbide phase of carbonsteel may be converted to graphite (3) Only killed steel shall be used above 850⁰F (455⁰C) (5) At temperatures over 1000⁰F (540⁰C), use only when the carbon content is 0.04 percent or higher (6) For temperatures above 1000⁰F (540⁰F), use only if the material is heat treated by heating it to a temperature of at least 1900⁰F (1040⁰C) and quenching in water or rapidly cooling by other means. |
(GPSA BOOK)
Gas Transmission and Distribution Piping
Code for Pressure Piping ANSI B31.8-1982
