Related Resources: fluid flow
Manometer Application Equation for Pressure
Fluids Flow Engineering
U-Tube Manometer Equation and Calculator
A Manometer is an instrument for measuring gas or vapor pressure- especially at low levels. Manometer's are used to measure the difference between dynamic and static pressures and may be configured as a u-tube, a single tube, or inverted depending on the application.
U-tube manometer measuring pressure relative to atmosphere (gauge pressure) equation.
p = pmgh
pm = density of manometer fluid (kg/m3 , lb/in3)
h = manometer reading or height difference (m, in)
g = acceleration due to gravity (9.81 m/s2 , 32.174 ft/s2)
p = Measured pressure ( N/m2, lb/in2)
Open: Manometer Pressure Calculators
U-tube manometer - differential pressure Equation
p = p1 - p2 = ( pm - pf) g h
p1 - p2 = Pressure Difference
pf = density of measured fluid. (kg/m3 , lb/in3)
p = Measured Pressure Difference ( N/m2, lb/in2)
Single-leg manometer - Gauge Pressure Equation
Measured pressure p = pmgh
Inclined single-leg manometer Measured Pressure Equation
Measured pressure p = pmgL sinθ
L = Length (m, in)
θ = Angle
Inverted U-tube manometer Equation
Pressure difference (p1 - p2) = (pf - pm)gh
p = p1 - p2 = Pressure Difference ( N/m2, lb/in2)
