Horsepower Required to Compress Air Equation and Calculator
Fluid Flow Table of Contents
Horsepower Required to Compress Air Equations and Calculator
The following calculator and equations gives data for the theorectical horsepower required to compress air from atmospheric pressure to various pressure - to mean effective pressures.
Horsepower Required to Compress Air Table Chart
Horsepower required to compress one cubic foot of free air per minute (isothermally and adiabatically) from atmospheric pressure (14.7 pounds per square inch) to various gage pressures. Single-Stage Compression, initial temperature of air, 60°F, jacket cooling not considered.
Adiabatically
The equation for calculating the horsepower required to compress isothermally a given volume of free air to a given pressure:
Isothermally
HP = Horsepower (ft-lb/sec) Adiabatic and Isothermally
N = number of stages in which compression is accomplished
P = atmospheric pressure in pounds per square inch
P2 = absolute terminal pressure in pounds per square inch
P2 = Gp + P in pounds per square inch
Gp = Gauge Pressure in pounds per square inch
V = volume of air, in cubic feet, compressed per minute, at atmospheric pressure
n = exponent of the compression curve = 1.41 for adiabatic compression
