Related Resources: fluid flow
Fluid Velocity Distribution within Pipes
Fluid Velocity Distribution within Pipes Equations
Velocity distribution at a cross section will follow a parabolic law of variation for laminar flow. Maximum velocity is at the center and is twice the average velocity. The following application are discussed:
- turbulent flows,
- smooth pipes,
- rough pipes,
- rough or smooth boundaries
The equation of the velocity profile for laminar flow can be expressed as
For turbulent flows, more uniform velocity distribution results. From experiments of Nikuradse and others, equations of velocity profiles in terms of center velocity vc or shear velocity µc follow.
(a) An empirical formula is
where:
n = 1/7 for smooth tubes, up to Re = 100,000
n = 1/8 | for smooth tubes for Re from 100,000 to 400,000
(b) For smooth pipes,
Eq. 3
For the yv*/v term,
Eq. 4
v* = (τ/ρ)0.5
(c) For smooth pipes (for 5000 < Re < 3,000,000) and for pipes in the wholly rough zone,
Eq. 5
In terms of average velocity V, Vennard suggests that V/vc may be written
Eq. 6
(d) For rough pipes,
Eq. 7
where ε is the absolute roughness of the boundary.
(e) For rough or smooth boundaries,
Eq. 8
also
Eq. 9
γ = specific (or unit) weight of fluid
hL = lost head
µ = absolute viscosity
L = Length of pipe
v = kinematic viscosity of the fluid in ft2/sec or m2/s
vc = Center velocity of fluid
v* = Shear velocity
r = radius, ft ot m
ro = radius of pipe
y = depth distance
V = mean (average) velocity in ft/sec or m/s
f = friction factor (Darcy) for pipe flow
µ = absolute viscosity in lb-sec/ft2 or N-s/m2
Schaum's Outline of Fluid Mechanics and Hydraulics
- Convergent Nozzle Flow Velocity and Area Equation and Calculator
- Convergent-Divergent Nozzle Flow Velocity and Area Equation and Calculator
- Viscosity of Fluid with Falling Sphere at Terminal Velocity Equation and Calculator Measurement of Viscosity in a Vertical Falling Ball Viscometer Calculator
- Pitot-Static Tube Velocity of Fluid Flow Measurement Calculator and Equation
- Velocity of Water Due To Head in Feet Table
- Velocity of Escaping Compressed Air Equation and Calculator
- Total Head Pressure Velocity Equations and Calculator
- Pipe Whip If a pipe were to rupture, the reaction force created by the high velocity fluid jet could cause the piping to displace and cause extensive damage
- Fluid Flow Open Channel Calculator Chezy and Manning's equation to determine the wetted perimeter, hydraulic radius, flow area, Chezy coefficient and flow velocity
- Velocity and Flow Capacity of Oil Standard Tubes Velocity and Flow Capacity of Oil Standard Tubes
- Velocity and Flow Capacity of Oil Schedule 40 Pipe Velocity and Flow Capacity of Oil Schedule 40 Pipe
- Velocity and Flow Capacity of Oil Schedule 80 Pipe Velocity and Flow Capacity of Oil Schedule 80 Pipe
- Velocity and Flow Capacity of Oil Schedule 160 Pipe Velocity and Flow Capacity of Oil Schedule 160 Pipe
- Flow Velocity Profiles Not all fluid particles travel at the same velocity within a pipe.
- Average (Bulk) Velocity Ia single average velocity to represent the velocity of all fluid at that point in the pipe.
- Liquid in Horizontal and Vertical Motion Equations and Calculator
- Compressibility of a Fluid Equations and Calculator
- Compressibility of Liquids Equations and Calculators
- Flow Through a Sluice Gate Formula and Calculator
- Flow over Channel Rise Hump Formula
- Fluid Flow Discharge Time under Falling Head Formula and Calculator
- Fluid Kinetic Force in Conduits Calculator and Equation
