Related Resources: fluid flow
Flow Rate of Steam Schedule 40 Pipe
HVAC Systems and Components
Fluids Engineering and Design
Flow Rate of Steam in Schedule 40 Pipe Tables
Many heating systems for large industrial buildings use high pressure steam (15 to 150 psig). These systems usually have unit heaters or large built-up fan units with blast heating coils. Temperatures are controlled by a modulating or throttling thermostatic valve or by face or bypass dampers controlled by the room air temperature, fan inlet, or fan outlet.
Pressure Drop Steam per 100 ft of Length |
Nominal Pipe Size, in. |
1/16 psi (1 oz/in2) |
1/8 psi (2 oz/in2) |
1/4 psi (4 oz/in2) |
1/2 psi (8 oz/in2) |
Sat. Press. psig |
Sat. Press. psig |
Sat. Press. psig |
Sat. Press. psig |
Sat. Press. psig |
Sat. Press. psig |
Sat. Press. psig |
Sat. Press. psig |
3.5 |
12 |
3.5 |
12 |
3.5 |
12 |
3.5 |
12 |
3/4 |
9 |
11 |
14 |
16 |
20 |
24 |
29 |
35 |
1 |
17 |
21 |
26 |
31 |
37 |
46 |
54 |
66 |
1-1/4 |
36 |
45 |
53 |
66 |
78 |
96 |
111 |
138 |
1-1/2 |
56 |
70 |
84 |
100 |
120 |
147 |
174 |
210 |
2 |
108 |
134 |
162 |
194 |
234 |
285 |
336 |
410 |
2-1/2 |
174 |
215 |
258 |
310 |
378 |
460 |
540 |
660 |
3 |
318 |
380 |
465 |
550 |
660 |
810 |
960 |
1,160 |
3-1/2 |
462 |
550 |
670 |
800 |
990 |
1,218 |
1,410 |
1,700 |
4 |
640 |
800 |
950 |
1,160 |
1,410 |
1,690 |
1,980 |
2,400 |
5 |
1,200 |
1,430 |
1,680 |
2,100 |
2,440 |
3,000 |
3,570 |
4,250 |
6 |
1,920 |
2,300 |
2,820 |
3,350 |
3,960 |
4,850 |
5,700 |
6,800 |
8 |
3,900 |
4,800 |
5,570 |
7,000 |
8,100 |
10,000 |
11,400 |
14,300 |
10 |
7,200 |
8,800 |
10,200 |
12,600 |
15,000 |
18,200 |
21,000 |
26,000 |
12 |
11,400 |
13,700 |
16,500 |
19,500 |
23,400 |
28,400 |
33,000 |
40,000 |
3/4 psi (12 oz/in2) |
1 psi |
2 psi |
Sat. Press. psig |
Sat. Press. psig |
Sat. Press. psig |
Sat. Press. psig |
Sat. Press. psig |
Sat. Press. psig |
3.5 |
12 |
3.5 |
12 |
3.5 |
12 |
3/4 |
36 |
43 |
42 |
50 |
60 |
73 |
1 |
68 |
82 |
81 |
95 |
114 |
137 |
1-1/4 |
140 |
170 |
162 |
200 |
232 |
280 |
1-1/2 |
218 |
260 |
246 |
304 |
360 |
430 |
2 |
420 |
510 |
480 |
590 |
710 |
850 |
2-1/2 |
680 |
820 |
780 |
950 |
1,150 |
1,370 |
3 |
1,190 |
1,430 |
1,380 |
1,670 |
1,950 |
2,400 |
3-1/2 |
1,740 |
2,100 |
2,000 |
2,420 |
2,950 |
3,450 |
4 |
2,450 |
3,000 |
2,880 |
3,460 |
4,200 |
4,900 |
5 |
4,380 |
5,250 |
5,100 |
6,100 |
7,500 |
8,600 |
6 |
7,000 |
8,600 |
8,400 |
10,000 |
11,900 |
14,200 |
8 |
14,500 |
17,700 |
16,500 |
20,500 |
24,000 |
29,500 |
10 |
26,200 |
32,000 |
30,000 |
37,000 |
42,700 |
52,000 |
12 |
41,000 |
49,500 |
48,000 |
57,500 |
67,800 |
81,000 |
Notes:
1. Flow rate is in lb/h at initial saturation pressures of 3.5 and 12 psig. Flow is
based on Moody friction factor, where the flow of condensate does not inhibit
the flow of steam.
2. The flow rates at 3.5 psig cover saturated pressure from 1 to 6 psig, and the rates at
12 psig cover saturated pressure from 8 to 16 psig with an error not exceeding 8%.
- Pressure Drop Along Pipe Length - Fluid Flow Hydraulic and Pneumatic
- Hydraulic and Pneumatic Design and Engineering
- Hazen-Williams Water Pressure Drop Flow Rates Equations and Calculator
- Liquid Pressure Drop in Pipe and Pipe Fittings Spreadsheet Calculator
- Pipe Friction Equations Within Pipe For Fluid Flow
- Estimated Pressure Drop for Thermoplastic Lined Fittings and Valves | Flow and Pressure Drop
References
- ASHRAE Handbook of Fundamentals, 2021 Inch-Pound Edition
