Capillary Number and Pressure Formulas and Calculators
Civil Engineering Design and Engineering
Fluids Engineering and Design
The capillary number (Nc) is a dimensionless quantity representing the relative effect of viscous drag forces versus surface tension forces acting across an interface between a liquid and a gas, or between two immiscible liquids.
Free (Basic) Membership minimum is required to use this calculator
Nc = µw V / σow
µw = Viscosity of Displacing Fluid (cP)
V = Characteristic Velocity (ft/D)
σow = Surface or Interfacial Tension of Oil and Water Phases (dyn/cm)
Nc = Capillary Number (dimensionless)
cP = centipose
Capillary pressure formula
Pc = 2 σ cos(θ) / r
σ = Fluid interfacial Tension (dyn/cm)
θ = Angle of Wettability (degree)
r = Radius of Capillary (cm)
Pc = Capillary Pressure (dyn/cm)
Wikipedia
- Capillary Action Review and Equations
- Viscometer Design and Application Review
- Fluid Flow Velocity Profiles
- Civil Engineering Formulas
- Area Development Planning (ADP) for Land and Buildings
- Average Permeability for Linear flow - Series beds Formula and Calculator
- Coulomb Active Earth Pressure Spreadsheet Calculator
- Rainfall Runoff Rate On Minor Size Land Formulas and Calculator
- Soil Permeability Review The coefficient of permeability k is a measure of the rate of flow of water through saturated soil under a given hydraulic gradient
