Spur Gear Calculator and Generator Download DXF, SVG or CSV Excel format files
Spur Gear Calculator and Generator - Download DXF, SVG or CSV Excel format files
Simular: Spur Gear and assembly Builder
Spur Gear Generator is unitless: you may choose inches, cm or millimeters when importing your DXF file as you will have the same value for D/P as it is set above or as imported (SI or imperial nits). Gears in SVG are measured in pixels, which is the value multiplied with the scale (Pixel per Unit) as it is displayed on the right side.
"Module" is the unit of size that indicates how big or small a gear is. It is the ratio of the reference diameter of the gear divided by the number of teeth.
Thus:
m = d / z
Module = Reference Diameter * Number of teeth
NUmber of teeth:
z = d / m
Number of teeth = Reference Number / Module
Reference pitch :
p = π * Module
Reference Pitch = Circumference / Number of teeth = ( π d ) / z
- Gear Types, Spur , Helical, Bevel, Rack and Pinion, Worm
- Spur Gear Design Tool Calculator
- Spur Gear Backlash Review | Spur Average Gear
- Gear Design Equations and Formula | Circular Pitches and Equivalent Diametral Pitches Table
- Force Analysis Spur Gears Equation and Calculator
