Pipe Flow Rate and Velocity Calculator
Fluid Flow Design and Engineering
Calculator will determine Pipe Flow Rate and Velocity required based on Head Loss, hL, and Frictional Pressure Drop, DPf, for given flow rate, Q, pipe diam., D, pipe length, L, pipe roughness, e, and fluid properties, r & m.
Moody Friction Factor Equation
Pipe Roughness Values
Preview: Pipe Flow Rate and Velocity Calculator
All calculators require a Premium Membership
NOTE: This is an iterative calculation, because an assumed value of Q is used to start the
calculations. If the final calculated value of Q is different from the assumed value, then the
assumed value of Q should be replaced with the calculated value of Q, leading to a new
calculated value for Q. This should be repeated as many times as necessary to get the
calculated value for Q to be the same as the assumed value. This iteration typically converges
rather rapidly.
This spreadsheet shows only the final assumed and calculated values of Q (when they are equal).
If the initial assumed value of Q was 1.5 cfs, then subsequent calculated and assumed values
for Q, leading to the final solution are as follows:
Assumed Q, cfs |
Calculated Q, cfs |
1.5 |
0.85 |
0.85 |
0.83 |
0.83 |
0.83 |
