Isentropic Flow of Fluid Equations and Calculator
Isentropic Flow of a Compressible Fluid Within a Conduit Equations and Calculator
Flow that is both adiabatic and frictionless is called isentropic flow. (Adiabatic means that no heat is transferred to the system from its surroundings or vice versa.) Isentropic flow exhibits no change in entropy. Isentropic flow is approximated in practice if the flow occurs very quickly (so there is little chance for heat transfer) and with a small amount of friction. Hence, isentropic analysis can be applied to high-velocity gas flow over short distances wherein friction and heat transfer should be relatively small.
Preview Isentropic Flow of Calculator
Isentropic flow can be analyzed by using the equations:
where:
v2 = velocity at point 2, ft/sec (m/sec)
v1 = velocity at point 1, ft/sec (m/sec)
p2 = pressure at point 2, lbs/ft2, (N/m2)
p1 = pressure at point 1, lbs/ft2, (N/m2)
k = specific heat ratio
γ1 = specific weight at point 1
γ2 = specific weight at point 2
The equation has some limitations that need to be pointed out. First of all, the equation should not
be used for large pressure drops. Also, the pipe diameter must be constant, and pressure changes due to
differences in elevation are considered negligible. Finally, it is limited to ordinary pressure ranges.
Approximate Properties of Some Gases [at 68° F (20°), 1 atm]
Gas | Specific Weight γ |
Adiabaic Exponent k |
lb/ft3 |
N/m3 |
Air | 0.0752 |
11.8 |
1.40 |
Ammonia | 0.0448 |
7.0 |
1.32 |
Carbon Dioxide | 0.1146 |
18.0 |
1.30 |
Methane | 0.0416 |
6.5 |
1.32 |
Nitrogen | 0.0726 | 11.4 | 1.40 |
Oxygen | 0.0830 |
13.0 |
1.40 |
Sulfur dioxide | 0.1695 |
26.6 |
1.26 |
Schaum's Outline of Fluid Mechanics and Hydraulics
- Isentropic Flow Relationships
- Isentropic Process Thermodynamic
- Isentropic Pressure and Volume
- Calculation of Mass Flow Rate Equation
- Mass Flow Rate Fluids Flow Equation
- Convergent Nozzle Flow Velocity and Area Equation and Calculator
- Continuity Equation Fluids Flow
- Convergent-Divergent Nozzle Flow Velocity and Area Equation and Calculator
- Viscosity of Fluid with Falling Sphere at Terminal Velocity Equation and Calculator Measurement of Viscosity in a Vertical Falling Ball Viscometer Calculator
- Pitot-Static Tube Velocity of Fluid Flow Measurement Calculator and Equation
- Velocity of Water Due To Head in Feet Table
- Conservation of Mass Fluids - Fluid Flow Hydraulic and Pneumatic
- Velocity of Escaping Compressed Air Equation and Calculator
- Total Head Pressure Velocity Equations and Calculator
- Pipe Whip If a pipe were to rupture, the reaction force created by the high velocity fluid jet could cause the piping to displace and cause extensive damage
- Fluid Flow Open Channel Calculator Chezy and Manning's equation to determine the wetted perimeter, hydraulic radius, flow area, Chezy coefficient and flow velocity
- Flow Velocity Profiles Not all fluid particles travel at the same velocity within a pipe.
- Average (Bulk) Velocity Ia single average velocity to represent the velocity of all fluid at that point in the pipe.
- Compressibility of a Fluid Equations and Calculator
- Compressibility of Liquids Equations and Calculators
- Flow Through a Sluice Gate Formula and Calculator
