Discharge Time under Falling Head Formulae and Calculator
Hydraulics & Pneumatic Engineering & Design
Fluids Engineering and Design
Civil Engineering and Design
Fluid Flow Discharge Time under Falling Head Formula and Calculator
The flow from a reservoir or vessel when the inflow is less than the outflow represents a condition of falling head. The time required for a certain quantity of water to flow from a reservoir can be calculated by equating the volume of water that flows through the orifice or pipe in time dt to the volume decrease in the reservoir. If the area of the reservoir is constant,
Formula 1
t = 2 · A / [ C · a · ( 2 g )1/2 ] · ( h11/2 - h21/2 )
h1 = head at the start, ft (m)
h2 = head at the end, ft (m)
A = Surface area of reservoir or vessel,
ft2 (m2)
t = time interval for head to fall from h1 to h2, s
C =
coefficient of discharge
a = area of discharge orifice, ft2 (m2)
g = 32.2 ft/s2 (9.81 m/s2)
- Head Changes Pipe Size Reduction Formula and Calculator
- Head Changes Caused by Pipe Size Enlargement Formula and Calculator
- Hydraulic Head Pressure
- Head Loss Darcy - Weisback Equation - Fluid Flow Hydraulic and Pneumatic
- Forced and Natural Fluid Circulation - Fluid Flow Hydraulic and Pneumatic
- Pipe Friction Equations Within Pipe For Fluid Flow
Civil Engineering Formulas SEcond Edition, Tyler G. Hicks, P.E.
