Convert Flat Oval Ducts to Round Sizes Formula and Calculator
Fluids Engineering Table of Contents
Hydraulic and Pneumatic Engineering
HVAC Engineering
Convert Flat Oval Ducts to Round Sizes, Formula and Calculator
To convert round ducts to flat oval sizes, use Equation (1) (Heyt and Diaz 1975), the circular equivalent of a flat oval duct for equal airflow and resistance.
To determine the round duct size, enter oval duct minor and major axis sizes to calculate round duct diameter De.
Preview: Convert Flat Oval Ducts to Round Sizes Calculator
De = ( 1.55 AR0.325 ) / P0.250
where AR is the cross-sectional area of flat oval duct defined as
AR = ( π a2 / 4 ) + a ( A - a )
and the perimeter P is calculated by
Eq. 3
P = π a + 2 ( A - a )
De = circular duct diameter for equal length, fluid
resistance, and airflow, in.
a = length one side of duct, in.
P = perimeter of flat oval duct, in.
A = major axis of flat oval duct, in.
a = minor axis of flat oval duct, in.
AR = cross-sectional area of flat oval duct, in2
- Heat Gain or Loss HVAC Duct ASHRAE Formula and Calculator
- Duct Design Air Flow Velocities
- Residential Duct Systems Design
- Ventilation Duct Stack Pressure Review, Formulas and Calculator
- HVAC Air Duct Flow Resistance Chart
- Round Duct Heat Transfer Coefficient Wall Temperature Heat Transfer Equation and Calculator
- ASME Code for Pressure Piping, B31.5, Refrigeration Piping and Heat Transfer Components
