Compressibility of a Fluid Equations and Calculator
Heat Transfer Engineering
Thermodynamics
Compressibility (also known as the coefficient of compressibility), β, is the fractional change in the volume of a fluid per unit change in pressure in a constant temperature process. Typical units are in2/lbf, ft2/lbf, 1=atm, and 1/kPa. (See Table 1.) It is the reciprocal of the bulk modulus, a quantity that is more commonly tabulated than compressibility. Equation 1 is written with a negative sign to show that volume decreases as pressure increases.
Compressibility changes only slightly with temperature. The small compressibility of liquids is typically considered to be insignificant, giving rise to the common understanding that liquids are incompressible.
Preview Premium Calculator: Compressibility of a Liqud Calculator
β = ( -ΔV / Vo ) / Δp
β = 1 / E
Eq. 3
ΔV = Vf - Vo
Eq. 4
Δp = pf - po
E = bulk modulus, lbf/ft2, (Pa)
β = compressibility, ft2/lbf, (Pa-1)
ΔV = Change of volume, ft3, (m3)
Vf = Volume final, ft3, (m3)
Vo = Volume compressed, ft3, (m3)
Δp = Change of pressure, lbf/ft2, (Pa)
po = Pressure initial, lbf/ft2, (Pa)
pf = Pressure compressed, lbf/ft2, (Pa)
Approximate Compressibilities of Common Liquids at 1 atm
Liquid | Temperature |
β (in2/lbf) |
β (1/atm) |
mercury | 32 °F |
0.028 x 10-5 |
0.39 x 10-5 |
glycerin | 60°F |
0.160 x 10-5 |
0.16 x 10-5 |
water | 60°F |
0.330 x 10-5 |
0.33 x 10-5 |
ethyl alcohol | 32 °F |
0.680 x 10-5 |
0.68 x 10-5 |
chloroform | 32 °F |
0.680 x 10-5 |
0.68 x 10-5 |
gasoline | 60°F |
1.0 x 10-5 |
1.0 x 10-5 |
hydrogen | 20K |
11 x 10-5 |
11 x 10-5 |
helium | 2.1K |
48 x 10-5 |
48 x 10-5 |
(Multiply 1/psi by 14.696 to obtain 1/atm.)
(Multiply in2/lbf by 0.145 to obtain 1/kPa.)
- Victor L. Streeter, Handbook of Fluid Dynamics, Ó 1961, by McGraw-Hill Book Company.
- Civil Engineering Reference Manual, Fifteenth Edition, Michael R. Lindeburg, PE
- Elastic Compression Bandage LaPlace's Law
- Archimedes Number Equation and Calculator
- Compressibility factor for air Z
- Continuity Equation Continuity equation is a mathematical expression of the principle of conservation of mass.
- Critical Pressure and Temperature Cavett Correlation for Oil Formula and Calculator
- Fluids Dynamic Simulator and stress reliever
- Gas Compressibility Factor (Gas Deviation Factor)
- Fritzsche Formula for Pressure Change at Standard Conditions Equation and Calculator
- Hydrostatic Pressure Force of a Fluid On Vessel Planes Equations The hydrostatic force of pressure F is that force which is exerted on the wall by the fluid
- Vessel With Pressure Applied to Liquid Level Equations and Calculator
- Relationship Between Depth and Pressure Relationship Between Depth and Pressure Review and Equations
- Pressure Distribution of a Fluid within a Vessel Equations and Calculator
- Head Loss Head loss is the reduction in the total head or pressure of the fluid as it moves through a fluid system.
- Fluid Characteristics Chart Table | Fluids Data, Fluids Density | Vapor Pressure | Kinematic Viscosity
- Fluid Characteristics Chart Table #2 | Fluids Data, Fluids Density
- Accumulator Sizing for Water Hammer Prevention in Pipelines Excel Spreadsheet Calculator
