Related Resources: belt design
Synchronous Timing Belt Standard Widths and Tolerances
Synchronous Timing Belt Standard Widths and Tolerances per. ANSI RMA IP-24, ISO 5299 and IS 9804.
- Synchronous Timing Belt Tooth Section Dimensions Table per ANSI / RMA IP-24
- Synchronous Timing Belt Pulley Dimensions Table per ANSI / RMA IP-24
- Synchronous Timing Belt Lengths and Tolerances per. ANSI RMA IP-24 Table
- Service Factors Synchronous Timing Belts
Belt
Section |
Standard Belt
Width |
Tolerances on Width for Belt Pitch Lengths
Up to
and including 33 in. |
Over 33 in.
up to and including 66 in. |
Over 66 in.
Designation
Dimensions
MXL (0.080)
012
019 025 |
0.12
0.19 0.25 |
+0.02
−0.03 |
XL (0.200)
025
037 |
0.25
0.38 |
+0.02
−0.03 |
L (0.375)
050
075 100 |
0.50
0.75 1.00 |
+0.03
−0.03 |
+0.03
−0.05 |
H (0.500)
075
100 150 |
0.75
1.00 1.50 |
+0.03
−0.03 |
+0.03
−0.05 |
+0.03
−0.05 |
200
2.00
+0.03
−0.05 |
+0.05
−0.05 |
+0.05
−0.06 |
300
3.00
+0.05
−0.06 |
+0.06
−0.06 |
+0.06
−0.08 |
XH (0.875)
200
300 400 |
2.00
3.00 4.00 |
+0.19
−0.19 |
+0.19
−0.19 |
XXH (1.250)
200
300 400 500 |
2.00
3.00 4.00 5.00 |
+0.19
−0.19 |
ANSI / RMA IP-24
ISO 5299
IS 9804
Machinerys Handbook, 27th Edition
