Engine Power Transmission & Technology
Engineering Application & Design
- Reciprocating engine education, technology and application resources.
- Should you find any errors omissions broken links, please let us know - Feedback
- Do you want to contribute to this section? See Premium Publisher Program
** Search this PAGE ONLY, click on Magnifying Glass **
Diesel Engines
- Four Stroke Diesel Cycle
- Intake Stroke
- Compression Stroke
- Fuel Injection
- Power (Combustion) Stroke
- Exhaust Stroke
- Basic Diesel Engine Cycle
- Diesel Engine Operation
- Major Components of a Diesel Engine
- Cylinder Block
- Crankcase and Oil Pan
- Cylinder Sleeve or Bore
- Piston and Piston Rings
- Connecting Rod
- Crankshaft
- Flywheel
- Cylinder Head and Valves
- Diesel Engine Camshaft, Timing Gears and Valve Mechanism
- Cooling System
- Lubrication System
- Fuel Delivery System
- Air Intake (Induction) System
Misc.
- Flat Belt Drive Design Calculator and Equations
- Roller Chain Drive Design Calculator and Equations
- Dynamometer Types, Equations and Calculators
- Heats of Combustion for Common Compounds
- Electric Motor Drive Simulator Python Script Application
- Pelton Wheel Review
- Wind Energy, Renewable Energy and the Environment Premium account required
- Wind Power Generation and Wind
- Average wind velocities at selected locations within the continental United States.
- Power Turbine Design
- Solar Powered Cooling Systems
- Solar Preheater
- Determining Operating Tire Pressure vs Load Calculator and Equation
- Photovoltaic Fundamentals
- Power Transmission Shaft Design Formulas and Calculator for Torsional Stress, Bending Stress and Tensile or Compressive Stress.
- Electric Motors, Third Edition premium membership required for access
- Motor Car Engineering, Volume II Design
Engine Equations
Renewable Energy
- Wind Energy Fundamentals
- Wind Turbine Blade Design
- Alternative Energy Systems in Building Design
- Solar Preheater
General
- Adaptive Control for Quadrotor UAVs
- Analysis and Design of Automotive Brake Systems. Engineering Design Handbook Premium Membership required
- Power Transmitted by Disk Clutch Formula and Calculator
- Diesel Electric Generating Plants - Premium Membership Required
- Power Transmission by Leather Belting
- Table of powers, speeds, transmission ratios, dimensions (orientation values) for Gearing
- Steady-State Torque of a Coupling Equations
- Vehicle Drive Line Optimal Design Guidelines
- Equation, 4-Stroke (Internal Combustion Engines)
- Flywheel Mass, Size Design Equations and Calculator
- Power Screw Design Equations and Calculator
- Reciprocating Engine Differential Pressure Compression Check
- Motor Generator Set Application / Specification
- Roller Chains Review
- Conductor Rail Review
- Keyway Cutter Hole Keyway Dimensional Data - ANSI/ASME B94.19-1997
- Stepper Control Motors Size and Dimensions Table Inch Units Round and Square Motors. For sizes NEMA Flange 17 to 56.
- Shaft Arbor and Keyseat Dimensional Data - ANSI/ASME B94.19-1997
- Shaft (Arbor) Keyway Dimensional Data - ANSI/ASME B94.19-1997
- Tire Traction Force Equation and Calculator
- Transmission Gear Ratio Equation and Calculator
- Wind Power Generation and Wind Power Turbine Design Premium Membership Required to view Document/Book
- Universal Joint Design and Engineering Equations
- Air Resistance Force to Vehicle Forward Motion Equation and Calculator
- Vehicle Speed on basis of engine rpm, tire size and gear ratios equations and calculator
- Distance traveled on uphill or downhill gradients Equation and Calculator
- Gradability and Traction Equation and Calculator
- Vehicle Hill Climbing Gradability taking into Account Road Tire Adhesion Equation and Calculator
- Rolling Resistance Force of Tire and Contacting Surface
- Power Take-Off (PTO) on Transfer Case Rotational Speed Per Distance Traveled (meter) Equations and Calculators
- Vehicle Turning Circle Design and Engineering Equations and Calculators
- Spark Plug Threads Sizes and Tapped Hole Table
- Truck and Car Axle Load Equations
- Trailer Hitch Ball Coupler Size Equations and Calculators
- Rigid Drawbar Trailers / Central Axle Trailers Loading Equations and Calculators
- Fifth Wheel Coupling Loading Equations and Calculators
- Sleeve Shaft Coupling Design Equations and Calculator
- Pinned Sleeve Shaft Coupling Design Equations and Calculator
- Truck and Cat Universal Joint Design and Engineering Formulas
- Wind Turbine Power From Wind Energy available in wind is basically the kinetic energy of large masses of air moving over the earth’s surface.
- Wind Turbine Power and Torque Equation and Calculator
- Universal Joint Maximum Minimum Speed
