Strength Properties Specifications for Steel Bolts
Hardware
ANSI Menu | Torque Design Menu
Strength of Materials
ASTM A490 series bolts are equivalent to ASTM A325 bolts in application and geometry, but are made to a higher strength. The imperial grades are made to the same strength specifications as ASTM A354 grade BD. The metric grades are made to the same strength specifications as ASTM F568M property class 10.9. Also, unlike their weaker counterparts they cannot be coated by hot-dip galvanization, mechanical deposition, or electroplating.
Because these bolts are designed to be used in structural applications the threaded length of the bolts are shorter to keep the threads out of the joint.
ASTM Designation No. |
Size Range, Inclusive |
Minimum Proof Strength, kpsi |
Minimum Tensile Strength, kpsi |
Minimum Yield Strength, kpsi |
Material |
A307 |
.25-1.5 |
33 |
60 |
36 |
Low Carbon |
A325, Type 1 |
0.5-1.0, 1.125-1.4 |
85, 74 |
120, 105 |
92, 81 |
Medium Carbon, Q&T |
A325, Type 2 |
0.5-1.0, 1.125-1.5 |
85, 75 |
120, 106 |
92, 82 |
Low Carbon Martensite, Q&T |
A325, Type 3 | 0.5-1.0, 1.125-1.6 |
85, 76 |
120, 107 |
92, 83 |
Weathering Steel, Q&T |
A354, |
Alloy Steel, Q&T |
A354, Grade BD |
0.25-4.0 |
120 |
150 |
130 |
Alloy Steel, Q&T |
A449 |
0.25-1.0, 1.125-1.5, 1.75-3.0 |
85, 74, 55 |
120, 105, 90 |
92, 81, 58 |
ASTM 490, Type 1 |
0.5 - 1.5 |
120 |
150 Min. |
130 |
Alloy Steel, Q&T |
ASTM 490, Type 2 | 0.5 - 1.0 |
120 | 150 Min. 173 Max. |
130 | |
ASTM 490, Type 3 | 0.5 - 1.5 | 120 | 150 Min. 173 Ma |
130 | Weathering Steel, Q&T |
ASTM A490M, Type 1 | 12 - 36 (mm) | 120 MPa | 1040 MPa | 940 MPa | - |
ASTM A490M, Type 2 (Withdrawn) | - |
ASTM A490M, Type 3 | - |
ASTM A490 and ASTM A490M are ASTM International standards for heavy hex structural bolts made from alloy steel. The imperial standard is officially titled Standard Specification for Structural Bolts, Alloy Steel, Heat Treated, 150 ksi Minimum Tensile Strength, while the metric standard (M) is titled Standard Specification for High-Strength Steel Bolts, Classes 10.9 and 10.9.3, for Structural Steel Joints.
Related Resources:
